Single-glazed glass door for a store
This topic has been viewed 8369 times and has 10 replies
Vuemme43
Country: Italia
Post by Vuemme43 »
I can not find the SweetHome 3D model of the single-glazed glass door for access to a store, can you help me?
Re: Single-glazed glass door for a store
Post by VeroniQ »
Buongiorno!
I often use this one.
You find some door models in the SH3D Sourceforge repository (a couple of glass ones too). Or, 3D warehouse search for glass door.
PS - an experimental, simple door with hinges in SF 3D models 508.
Bubblobill
Country: Australia
Post by Bubblobill »
Glass-Door.zip
I made this.
Enjoy
Country: UK
Post by Mike53 »
Thank you for sharing the door Bill, i do like the way you have set up the handles, unfortunately, there is a gap between the frame and the door, when positioned in a wall sweet home 3d will fill that gap with wall, 2 other points of less importance, it is only 800mm tall and it is needs to be imported as a door.
I noticed the issue with the gap because i have done the same [:(].
Good luck and hope to see more.
Bubblobill
Country: Australia
Hmmm... I put the air gap in on purpose for accuracy. I suppose I shall just have to take it out.
The whole unit is supposed to be 80" tall based on a commercial spec I found somewhere. Resize to 203cm for correct sizing.
Bubblobill
Country: Australia
New link to file. Closed air gaps between frame and door as suggested by Mike53.
Glass-Door.zip
Bubblobill
Country: Australia
Updated again. Now has a threshhold
Glass-Door.zip
Bubblobill
Country: Australia
I declare this to be the last version I can be bothered with. I even added swing area and stuff.
Enjoy
Glass-Door.sh3f
Country: UK
Post by Mike53 »
Better, but wall still visible, threshold slight issue, flickering, opaque? Even added to library it is still an object not a door, reopen with furniture editor and define as door
Image Image
MIke [:)]
