cool Sliding door glazed
This topic has been viewed 15259 times and has 8 replies
Sliding door glazed
Post by bdfd »
Here are two new models of sliding doors glazed, one opened and the another closed.
Closed
Opened
Download and unzipp them before to import.
IMPORTANT !
do not forget :
to add an standard embrasure in black color,
for import, click on the option 'door and window',
to remove the magnetism to put the sliding door glazed,
Put the sliding door glazed near the wall, not in.
# This file is distributed under the CC-BY Creative Commons Attribution 3.0 Unported license
# available at http://creativecommons.org/licenses/by/3.0/ or under the terms of the GNU General Public License
# as published by the Free Software Foundation and available at http://www.gnu.org/copyleft/gpl.txt
Verriere fermee = closed
Verriere ouverte = opened
Regards.
Verriere ouverte.zip
(139.54 KiB) Downloaded 516810 times
Verriere fermee.zip
(129.05 KiB) Downloaded 515832 times
Re: Sliding door glazed
Post by VeroniQ »
Well done, Bdfd, and so fashionable!
..add an standard embrasure in black color, for import, click on the option 'door and window', to remove the magnetism to put the sliding door glazed, Put the sliding door glazed near the wall, not in.
Or add library properties (see thread 2006 for the whole shebang), something like this guestimate:
doorOrWindow#1=true
doorOrWindowCutOutShape#1=M 0.029,0.04 h0.46 v.962 h-0.46 z
doorOrWindowWallThickness#1=15
doorOrWindowWallDistance#1=-6.2
Or even edit the [font=courier new]<doorOrWindow .../> [/font] properties in [font=courier new]Home.xml[/font] replacing:
wallCutOutOnBothSides='true' boundToWall='false'
by something like:
wallThickness='0.903616' wallDistance='-0.373494' cutOutShape='M 0.029,0.04 h0.46 v.962 h-0.46 z' wallCutOutOnBothSides='true'
Backup first, though, easy to make a mess [:)] The cutout will be the same in both cases, but in [font=courier new]Home.xml[/font] all values are relative to model size, also wall alignment. As model is 16.6 deep wallThickness = 0.903616 (15/16.6) and wall Distance -0.373494 (-6.2/16.6).
PS. In light of the hols approaching, all concerned with dietary requirements of models, there is information in SF 3D models 261. Combined with a bit of editor magic, it is quite astonishing how small it is possible to make a model.
Post by bdfd »
Thanks to Lady Vero & okh.
It's an another way to give 3D models with automatic import. [;)]
Sorry, do not get it. Could you rephrase, please? ok
Post by bdfd »
A sh3f file can be importing into sh3d automatically.
..sh3f file...
Ah yes. I might have mentioned that library is about .sh3f files; and that while the cutout is available from the editor, the other properties must be added manually to PluginFurnitureCatalog.properties inside the .sh3f file. But then, that is what thread 2006 is all about.
Post by bdfd »
If you want, you can update the colors by another colors or textures.
Comments are welcoming by PM. [;)]
Hexilium
Post by Hexilium »
I used it in my project, so thank you.
Too often, reaching for thoughts, we abuse our patience Księgowa Jelenia Góra.
