Re: Curved Walls
This topic has been viewed 8570 times and has 4 replies
stef.salmon
Country: UK
Re: Curved Walls
Post by stef.salmon »
I might be being a bit stupid in my question!
Is there a way of drawing curved walls easily? I have done this on the attached file, but they are made up of lots of smaller walls.
https://www.dropbox.com/s/mwre54mvxe0n4 ... s.png?dl=0
Country: UK
Re: Curved Walls
Post by Mike53 »
Hi stef
Simple answer is yes. Draw the wall you want arced as a straight line, go to "modify wall" and enter the required or estimated arc in degrees, since ver 6 release you may have noticed a small arrow on 1 side of the walls as you highlight them, this indicates which way the wall will arc. Or use can use your mouse, place the icon near the arrow of a highlighted wall,left click and drag the wall to the arc you desire.
Hope this explains it.
stef.salmon
Country: UK
Re: Curved Walls
Thanks Mike.
I did notice the small arrow on the side. I will give it a try.
Seniram
Re: Curved Walls
Post by Seniram »
How can I create curved walls is there is no arrow on the wall or arc extent secgtion in the modify walls edit box? I am using version 2.1.
Re: Curved Walls
Seniram, this feature was added in version 3. But why do you use such an old version?
