Curved Shower (Base & Glass Walls
This topic has been viewed 11809 times and has 3 replies
captainkirk
Post by captainkirk »
does anyone know a simple way to model this shower in Sweet Home 3D?
http://www.kinetikhardware.com/en/?page=130
I couldn't find any type of curved object (furniture, etc) that I could use
thanks for help!
Kirk
db4tech
Country: UK
Re: Curved Shower (Base & Glass Walls
Post by db4tech »
Hi Kirk,
Welcome to the Sweet Home forum.
Probably the easiest way would be to model it in a 3D application, such as Art of Illusion, then import the model and build the rest of the bathroom scene from there.
Just built this glass door for you (attached to the end of this message), to help get you started.
If you would like a curved part for the shower base, have a look on the Sweet Home 3D models page, round wall part, I was going to use and adapt this, for the glass door, but it was too thick, so built a door using Art of Illusion instead.
Look forward to seeing your completed bathroom. [:)]
db4tech
Curved_glass_door.zip
(1.33 KiB) Downloaded 2558 times
captainkirk
Thanks, hope to try this tomorrow!
cheers, Kirk
db4tech
Country: UK
Post by db4tech »
With the picture you supplied being a computer render, could you (legally) access the actual original shower model? If so, it could be converted into either obj or 3DS format, then it can be imported in to Sweet Home.
db4tech
