Windows 10 update problem?
This topic has been viewed 6010 times and has 3 replies
robertvk
Country: Australia
Post by robertvk »
Windows 10 updated yesterday, and now SweetHome doesn't render the thumbnails at all, or very very slowly:
Never seen this before...Any advice welcome!
Thanks, Robert
Re: Windows 10 update problem?
If your computer runs an old enough Intel processor with integrated graphics under 64 bit, you should try the parameters [font=courier new]/j3d.version=1.5.2 /os.arch=x86[/font] of the installer explained here.
bkdroid13
Post by bkdroid13 »
Very true, it happened with me also today. I had to literally turn off my Windows updates which took me another one hour. But all thanks to Google.
Refer this guide: https://www.hows.tech/2019/04/disable-w ... pdate.html
If it is something with Java, you need to increase Java Heap Space.
Jonnie63
Post by Jonnie63 »
I would like to suggest that it is completely useless in most cases trying to stop Windows10 updates, people who stopped them early enough seem to have managed but of course new updates means more counter measures to circumvent the hacks you have implemented which worked on an earlier enough "version" of windows10 but will not work now, its like trying to use out of date virus software when the computer viruses have evolved to outwit the old virus definitions.
I tried most hacks featured on a forum which was very active on this subject but as far as I know without exception all of the hacks eventually failed.
If you shut one door another will open a few months later - its like trying to beat the designer of an immersive maze or puzzle when they know where all the trap doors are and you don't.
I even tried a firewall approach blocking all known Microsoft severs but guess what - they just add more servers which meant I would be constantly updating my list of banned servers.
I ranted and raved like the rest for about one year and then I did actually find a solution - the only one I believe that actually works.
I moved over to LINUX and I have been loving it ever since, finally I have control over my machine again and I say what gets updated or not.
Since moving to Linux nothing has broken on my machine - the windows updates in contrast were constantly breaking drivers which rendered my top end CADCAM software useless until I spent a few hours restoring everything as it should be. I have found good quality alternatives (free) for almost everything I used to do previously.
My advice dont waste your energy fighting the system, life is just too short, its better to decide to live with it or migrate, I migrated but that will not be the best choice for everyone.
I wish I had moved to Linux earlier and saved myself a lot of stress and frustration.
I still have a windows partition on my machine for when I absolutely need to use software only available on Windows10 but I have disabled all Wifi accounts on the windows partition so that there is zero internet connection and I take care never to have the machine plugged in directly to ethernet when I am using windows10. Everything I do online I do on Linux. As far as I know my windows machine partition is now indeed frozen in time but at the cost of zero internet connectivity - I do most things including online activity on Linux.
SweetHome3D works just fine on Linux [:)] [:)] [:D] [:D] [\:D/]
