Windows 10 display issue
This topic has been viewed 32391 times and has 21 replies
RebTech
Country: Canada
Post by RebTech »
every time I start the program and try and move my mouse around...this is what I end up with?
any solutions to this video display issue? using the lattest ver
Version 5.5.2 Java version 1.8.0_144 / 64 bit / 5 GB max
Re: Windows 10 display issue
Could you try to reinstall the program using the options described here?
Treglis
Post by Treglis »
I had the same issue. This helped me to solve the problem http://www.sweethome3d.com/support/foru ... 7628#34466
Nik_2213
Country: United Kingdom
Post by Nik_2213 »
Are you using the bundled graphics driver, which may be optimised for gaming ? You may need a generic driver from the chip-maker eg Nvidia...
Scrati
Post by Scrati »
I have the exact same problem with version 5.7 and before. I even tried 3.6 which I found in one of my backup folders.
I tried the hints in post number 2 and 3 and I have original graphics drivers installed.
Has anybody any ideas?
sfcusaoh
Country: United States
Post by sfcusaoh »
I am having the same problem...
I have Sweet Home 3D version 5.7 and Java jre1.8.0_171 installed on an Asus G752VL i7 2.6GHz processor with 12GB ram running Win10 64bit.
Replacing the Sweet Home 3D bin & lib files with the Java bin & lib files did not correct the issue.
Does anybody have any ideas?
Thanks in advance for your help...
dusho
Post by dusho »
Also having this issue and nothing from what is mentioned here helped. Tried portable, tried jre 1.6, tried sh3d version 3.4, tried disabling java3d by env. variable (now causing directX/opengl error at start up).
Issue starts right away when any tooltip appears, then it feels like re-paint is totally messed up (almost like double buffer content is painted where your mouse is).
Found also other SW with similar reports: https://github.com/chatty/chatty/issues/69
My setup is Win10, 64-bit, Asus G752, Nvidia GTX1070, factory drivers
ErikJan
Country: The Netherlands
Post by ErikJan »
Exactly what I see too
MoritzWb
Post by MoritzWb »
Same here, still no solution?
From version 6.0, the destination folder screen in Sweet Home 3D installer shows Architecture options to install the program in 32 bit or 64 bit. Did you try the 32 bit option?
