Hello everybody,
Can you change the font size of the numbers in the dimension specification? In my plan, I can change the font size of the numbers of the area specification (Ctrl + Alt + K), but not the font size of the numbers in the dimension specification. And this is so small that you can hardly see it..
Greetings
Jürgen
Change font size in dimension numbers
This topic has been viewed 9813 times and has 3 replies
Re: Change font size in dimension numbers
That should be the same shortcut. Did you try Plan > Modify text size > Increase size menu item after selecting the dimension lines?
I have a similar query... using MacOS I see the option in the PLAN menu and the keyboard shortcut is ^⌘+ BUT I'm not sure which keypress to use for "caret" the first symbol?
Maybe you have an old keyboard, but on mine, the symbol ^ is written at the top the control key.
