Is It Possible to Reset Dimension Text to a Default Size?
This topic has been viewed 2146 times and has 2 replies
mikedj
Post by mikedj »
I have several dimensions that I've individually increased and decreased to various sized text, so it's very inconsistent throughout my plan. Is there a way to set dimensions text to a specific size, as can be done with regular text?
Thanks,
Daniels118
Country: Italy
Re: Is It Possible to Reset Dimension Text to a Default Size?
Post by Daniels118 »
Option 1
Select all dimension lines, hold down CTRL+ALT+SHIFT, then press repeatedly "K" to reduce the text size of all dimension lines up to the minimum value; then hold CTRL+ALT, and press "K" 11 times to increase the size again to the same value for all the dimension lines.
Option 2
Close the program, then open the home file with any zip extractor, edit the Home.xml file with any text editor and change the value of the fontSize attribute for all the dimensionLine>textStyle nodes. Save the file and pack it back into the home file.
mikedj
Post by mikedj »
Brilliant. Thank you!
