Hello everyone,
I’m using this program about 3 years and I have only one problem: at one point it blocks-turn off and RESET. And I mean that disappear all imported models. And it happened about a dozen times or maybe more.
It just happens to me? [:((]
maybe they have already spoken, but I don’t find the discussion on forum. Someone can help me understand what it is that I'm wrong?
My Operating system is Windows 10, the program sweet home 3d 2016 (the last) .
Thank you
(translation italian-english by google)
Salve a tutti,
uso questo programma da circa 3 anni e ho un solo problema: a un certo punto si blocca-si spegne-si RESETTA. E intendo che scompaiono tutti i modelli importati. E mi è successo circa una decina di volte o forse di più.
Succede solo a me?
magari ne hanno già parlato ma non trovo la discussione. qualcuno può aiutarmi a capire cos'è che sbaglio?
Grazie
when the program is reset
This topic has been viewed 9963 times and has 7 replies
- AngeloFolle
- Country: Italy
Re: when the program is reset
Do you use the Online version or the installer version?
- AngeloFolle
- Country: Italy
installer version
Under Windows 10, imported furniture and textures are stored in the folder C:\Users\user\AppData\Roaming\eTeks\Sweet Home 3D where user is your login.
Maybe you have a tool on your computer that cleans your data folder? Does it happen on a regular basis (every day, every week...)?
- AngeloFolle
- Country: Italy
i just use CCleaner Free (three times a week), but the cleanliness does not coincide with the occurrence of the reset.
The program SH3D is reset about 6 months or 3.
- AngeloFolle
- Country: Italy
For the record: the problem is not solved. I'm quite tired of this.
please, I would like to know if someone has a solution.
Sorry, you shouldn't hope to recover data you lost 3 months ago.
Did you check that the content of the folder C:\Users\user\AppData\Roaming\eTeks\Sweet Home 3D changes when you import some furniture? If it's the case, it means that Sweet Home 3D works correctly and the program doesn't remove any of the imported furniture unless you delete them from the catalog.
Anyway, if you want to backup the imported furniture, you could also create some furniture libraries with the plug-in ExportToSH3F.
- AngeloFolle
- Country: Italy
Thanks,
i will do in this way
