Grouping of plug-in actions
This topic has been viewed 8651 times and has 3 replies
enkonyito
Post by enkonyito »
Is it possible to group the plug-in actions on the Tools menu as actions "Create photo...", "Create photos at points of view..." and "Create video..." of the 3D View menu?
By default, all actions of a plug-in are separated in Tools menu.
EnkoNyito
Re: Grouping of plug-in actions
Not in the current version, since a separator is added before each plug-in menu item.
I guess it would be nice, but specifying groups of menu items might not be so easy to implement. If you have a simple idea, please share it.
enkonyito
Post by enkonyito »
I thought that adding a loop with the list of plug-ins to put a separator after the last action of a menu would work.
A plug-in as AdvancedEditing can have several actions divided in different menus so it is not easy to group them by menu.
EnkoNyito
enkonyito
Post by enkonyito »
What do you think about this?
    // Add menus to menu bar
    JMenuBar menuBar = new JMenuBar();
    fileMenu.addSeparator(); // test (enkonyito)
    menuBar.add(fileMenu);
    editMenu.addSeparator(); // test (enkonyito)
    menuBar.add(editMenu);
    furnitureMenu.addSeparator(); // test (enkonyito)
    menuBar.add(furnitureMenu);
    if (controller.getPlanController().getView() != null) {
      planMenu.addSeparator(); // test (enkonyito)
      menuBar.add(planMenu);
    if (controller.getHomeController3D().getView() != null) {
      preview3DMenu.addSeparator(); // test (enkonyito)
      menuBar.add(preview3DMenu);
    menuBar.add(helpMenu);
    // Add plugin actions menu items
    // debut test (enkonyito)
    // Create missing menu
    for (Action pluginAction : this.pluginActions) {
      String pluginMenu = (String)pluginAction.getValue(PluginAction.Property.MENU.name());
      if (pluginMenu != null) {
        boolean pluginMenuExisting = false;
        for (int i = 0; i < menuBar.getMenuCount(); i++) {
          JMenu menu = menuBar.getMenu(i);
          if (menu.getText().equals(pluginMenu)) {
            pluginMenuExisting = true;
            break;
        if (!pluginMenuExisting) {
          // Create missing menu before last menu
          JMenu menu = new JMenu(pluginMenu);
          menuBar.add(menu, menuBar.getMenuCount() - 1);
    // Group plug-in actions by menu
      for (Plugin plugin : this.plugins) {
        boolean pluginActionAdded = false;
        createActionsPlugin(plugin);
        for (Action pluginAction : this.actionsPlugin) {
              // Add menu item to existing menu
              menu.add(new ResourceAction.MenuItemAction(pluginAction));
              pluginActionAdded = true;
        if (pluginActionAdded) {
          menu.addSeparator();
    // fin test (enkonyito)
  //debut test (enkonyito)
  private void createActionsPlugin(Plugin plugin) {
    this.actionsPlugin = new ArrayList<Action>();
    if (plugin != null) {
      for (final PluginAction pluginAction : plugin.getActions()) {
        // Create a Swing action adapter to plug-in action
        this.actionsPlugin.add(new ActionAdapter(pluginAction));
  //fin test (enkonyito)
before
after
EnkoNyito
