Is it possible to group the plug-in actions on the Tools menu as actions "Create photo...", "Create photos at points of view..." and "Create video..." of the 3D View menu?
By default, all actions of a plug-in are separated in Tools menu.
Grouping of plug-in actions
This topic has been viewed 8422 times and has 3 replies
Re: Grouping of plug-in actions
Not in the current version, since a separator is added before each plug-in menu item.
I guess it would be nice, but specifying groups of menu items might not be so easy to implement. If you have a simple idea, please share it.
I thought that adding a loop with the list of plug-ins to put a separator after the last action of a menu would work.
A plug-in as AdvancedEditing can have several actions divided in different menus so it is not easy to group them by menu.
EnkoNyito
What do you think about this?
before
after
// Add menus to menu bar
JMenuBar menuBar = new JMenuBar();
fileMenu.addSeparator(); // test (enkonyito)
menuBar.add(fileMenu);
editMenu.addSeparator(); // test (enkonyito)
menuBar.add(editMenu);
furnitureMenu.addSeparator(); // test (enkonyito)
menuBar.add(furnitureMenu);
if (controller.getPlanController().getView() != null) {
planMenu.addSeparator(); // test (enkonyito)
menuBar.add(planMenu);
if (controller.getHomeController3D().getView() != null) {
preview3DMenu.addSeparator(); // test (enkonyito)
menuBar.add(preview3DMenu);
menuBar.add(helpMenu);
// Add plugin actions menu items
// debut test (enkonyito)
// Create missing menu
for (Action pluginAction : this.pluginActions) {
String pluginMenu = (String)pluginAction.getValue(PluginAction.Property.MENU.name());
if (pluginMenu != null) {
boolean pluginMenuExisting = false;
for (int i = 0; i < menuBar.getMenuCount(); i++) {
JMenu menu = menuBar.getMenu(i);
if (menu.getText().equals(pluginMenu)) {
pluginMenuExisting = true;
break;
if (!pluginMenuExisting) {
// Create missing menu before last menu
JMenu menu = new JMenu(pluginMenu);
menuBar.add(menu, menuBar.getMenuCount() - 1);
// Group plug-in actions by menu
for (Plugin plugin : this.plugins) {
boolean pluginActionAdded = false;
createActionsPlugin(plugin);
for (Action pluginAction : this.actionsPlugin) {
// Add menu item to existing menu
menu.add(new ResourceAction.MenuItemAction(pluginAction));
pluginActionAdded = true;
if (pluginActionAdded) {
menu.addSeparator();
// fin test (enkonyito)
//debut test (enkonyito)
private void createActionsPlugin(Plugin plugin) {
this.actionsPlugin = new ArrayList<Action>();
if (plugin != null) {
for (final PluginAction pluginAction : plugin.getActions()) {
// Create a Swing action adapter to plug-in action
this.actionsPlugin.add(new ActionAdapter(pluginAction));
//fin test (enkonyito)after
EnkoNyito
