How can I create a ramp?
This topic has been viewed 10133 times and has 5 replies
Hello, I'm doing an underground parking, so, somebody knows how can I create a ramp or a triangle to simulate the inclined road to the parking places?? Thank you for the help.
Re: How can I create a ramp?
Use a triangle (or other shape) placed at the lower level - i.e. in the ground. There are several threads about this in the forum, but I cannot find them off hand. Good luck. ok
[email protected]
- Country: US
Hello, I would suggest considering just using a wall, double clicking it and then choose the 'Sloping wall' option. Give it a thickness to represent the width of the ramp. Height start and end provide the slope desired. It worked out in a quick test I did.
The triangle or shape and the wall would both work well, the wall has the advantage that it can be arced but the disadvantage that it has a minimum height, which may be higher than the floor.
There is a ramp in the example 6 of the Gallery (made with a triangle, in the basement)
- bdfd
You can see one of my projects HERE
There are three ramps at different levels... Shape, wall or triangle are the same thing, it's not easy to locate them.
