For increasing the max memory, as well as HiDPI adjustments (http://www.sweethome3d.com/support/foru ... _offset,10), Linux users are asked to modify the startup script, which is understandable.
However, this script is part of the installed files, which should not be modified after install, and which will be lost after the next upgrade.
Would it be possible to configure these flags somewhere else, such as in a SweetHome3D.l4j.ini file under ~/.eteks ?
SweetHome3D.l4j.ini in Linux
This topic has been viewed 7037 times and has 1 replies
Re: SweetHome3D.l4j.ini in Linux
This .ini file is a feature of launch4j which is used only under Windows.
So this might be possible under other systems but it would require some development...
