SweetHome3d Not Seeing My Data Partition in Linux
This topic has been viewed 12968 times and has 17 replies
jmadero
Post by jmadero »
Hi All,
I've been using Linux for over 15 years and I can say this is a first. Sweet Home 3D is not seeing my main data partition. I separate /, /home, and /data, for various reasons.
lsblk output
├─sdb5   8:21   0  29.3G  0 part /
├─sdb6   8:22   0  24.4G  0 part /home
├─sdb7   8:23   0 222.7G  0 part /data
SweetHome3d Open Dialog
Additionally, my shortcuts to the /data/XXXX folders within my Home Folder are all missing in SH3D. Finally, permissions are pretty standard, 770, for the data partition.
This is super bizarre. Any suggestions welcome.
dorin
Re: SweetHome3d Not Seeing My Data Partition in Linux
Post by dorin »
Me too. I have also separate partitions for different purpose.
Normal. All other programs act the same (Libre Office, Inkscape, kate etc.)
At start are mounted in system ONLY "/" and "/home".
All other partitions have only shortcuts in file browser.
First I need to click on it then insert the root password to mount it in the system.
For many personal reasons I don't like to use sudo.
After that I found it in file chooser (from every program) under:
Root/media/ my_user_name / partition_name
That's applicable for every new reboot or boot.
At least that's the way I use my linux systems.
I use debian with KDE.
Hope is useful.
P.S. An general advice: DON'T use the repository version.
Use the installer version from this site.
UbuntuBirdy
Country: Switzerland
Post by UbuntuBirdy »
I'm using Linux (Ubuntu) only since 12 years, so you guys are the pros. But I solved this problem with "systemd":
systemd man page.
I put it in the fstab so a mount point looks like this:
/home/"user"/music nfs nfsvers=4,noauto,x-systemd.automount,x-systemd.idle-timeout=900,users,rw 0 0
This is for a NAS via nfs, but it works also for partitions.
The mount point is not mounted (this saves you booting time) until you access it, but all the programs can do that.
Perhaps this could be a solution for you...
Pascal
jmadero
Post by jmadero »
It is mounted. LibreOffice and every other application sees the mount and I have permissions to access. It's literally just Sweet Home 3d. It's an EXT4 partition.
UbuntuBirdy
My partitions, NAS, server, RaspberryPi, all mounted with systemd the way I wrote it in my last post, are all accessible with Sweet Home 3D without any restrictions. And these are Ext4, FAT or NTFS partitions.
So, for me systemd is the one and only thing to mount with (also because of many other options and features).
Pascal
jmadero
Post by jmadero »
Thought that some additional details could help:
FSTAB
UUID=06461143-2fd0-4dee-b4cd-826690435ec5 /data ext4 defaults 0 2
View from LibreOffice Dialog:
View from Sweet Home Dialog:
As can be seen, "/data" is just entirely missing from Sweet Home Dialog....it's extremely bizarre. I can see /data in LibreOffice and access it without a hitch.
jmadero
Post by jmadero »
UbuntuBirdy
and what's in the "mnt" folder?
Pascal
jmadero
Post by jmadero »
/mnt/Synology
/mnt/Windows
(two other shares in my FSTAB)
UbuntuBirdy
Ok, other idea: normally you need root rights to access any folder or file in the root directory (they are read-only). So, could this be the reason for your issue?
Pascal
Users browsing this forum: DuckDuckGo [Bot], Google [Bot]
