Hello All
I'm new here so please go easy on me until I get the protocol right.
I am doing a house design, and would like to place recessed niches in the walls.
I have done some searching but have been unable to get an idea of how to do this.
Is it even possible, and how do I begin?
Thanks in advance for any assistance
regards
Ray
wall niche
This topic has been viewed 4961 times and has 3 replies
Re: wall niche
Maybe you should read this ...
Re: wall niche
Thanks.....did that.....the problem it seems was that I had the service hatch inside the wall and wasn't showing...the link you provided had the answer
Can the shape of the hatch be easily changed?....for instance....I would like to make the top horizontal edge have a 22deg slope
Regards
Regards
Re: wall niche
Easiest I can come up with off hand would be to fill the top of the niche with a home made model. You can use the Shape Generator plug-in to create the shape. You may also want to have a look at the blogpost: How to create a hole at the bottom of a wall.
