How to make 3D Models visible to sweethome3D?
This topic has been viewed 4853 times and has 3 replies
rdorsch
Post by rdorsch »
since Debian still ships sweethome 4.5, I downloaded version 5.2 myself and unpacked it to
rd@blackbox:/opt/SweetHome3D$ ls -l
insgesamt 8
drwxr-xr-x 10 root root  4096 Mär  6 15:00 3DModels
drwxr-xr-x  4 rd   users 4096 Feb 19 20:12 5.2
rd@blackbox:/opt/SweetHome3D$ ls -l 5.2/
insgesamt 144
-rw-r--r-- 1 rd users 18007 Feb 19 20:12 COPYING.TXT
drwxr-xr-x 8 rd users  4096 Mär  6 14:48 jre1.6.0_45
drwxr-xr-x 2 rd users  4096 Mär  6 14:48 lib
-rw-r--r-- 1 rd users   901 Feb 19 20:12 LICENSE.TXT
-rwxr-xr-x 1 rd users   844 Feb 19 20:12 SweetHome3D
-rw-r--r-- 1 rd users 11873 Feb 19 20:12 THIRDPARTY-LICENSE-BATIK.TXT
-rw-r--r-- 1 rd users 10233 Feb 19 20:12 THIRDPARTY-LICENSE-CONTRIBUTIONS.TXT
-rw-r--r-- 1 rd users  8029 Feb 19 20:12 THIRDPARTY-LICENSE-ITEXT.TXT
-rw-r--r-- 1 rd users 22286 Feb 19 20:12 THIRDPARTY-LICENSE-JAVA3D.TXT
-rw-r--r-- 1 rd users 11519 Feb 19 20:12 THIRDPARTY-LICENSE-JAVA.TXT
-rw-r--r-- 1 rd users 21381 Feb 19 20:12 THIRDPARTY-LICENSE-JMF.HTML
-rw-r--r-- 1 rd users  1680 Feb 19 20:12 THIRDPARTY-LICENSE-SUNFLOW.TXT
-rw-r--r-- 1 rd users    93 Feb 19 20:12 THIRDPARTY-LICENSE-TANGO.TXT
-rw-r--r-- 1 rd users  8031 Feb 19 20:12 THIRDPARTY-LICENSE-VECTORGRAPHICS.TXT
rd@blackbox:/opt/SweetHome3D$ ls -l 3DModels/
insgesamt 32
drwxr-xr-x 2 root root 4096 Mär  6 14:59 3DModels-BlendSwap-CC-0-1.6.1
drwxr-xr-x 2 root root 4096 Mär  6 14:55 3DModels-BlendSwap-CC-BY-1.6.1
drwxr-xr-x 2 root root 4096 Mär  6 14:56 3DModels-Contributions-1.6.1
drwxr-xr-x 2 root root 4096 Mär  6 15:00 3DModels-KatorLegaz-1.6.1
drwxr-xr-x 2 root root 4096 Mär  6 14:53 3DModels-LucaPresidente-1.6.1
drwxr-xr-x 2 root root 4096 Mär  6 14:58 3DModels-Reallusion-1.6.1
drwxr-xr-x 2 root root 4096 Mär  6 15:01 3DModels-Scopia-1.6.1
drwxr-xr-x 2 root root 4096 Mär  6 15:01 3DModels-Trees-1.6.1
Sweethome tells me at startup that new versions of the 3D models are available (version 1.6). It seems it does not find the versions I downloaded. In the Settings I did not find a configuration for the 3D model search path.
Can anybody tell how to tell sweethome3D in which paths the libraries are located?
Thanks
Rainer
Re: How to make 3D Models visible to sweethome3D?
- Make hidden directories visible with CTRL-H
- Goto subdirectory .eteks
- Goto subdirectory sweethome
- There you will find subdirectories for plug-ins, textures and furniture
- Copy the library or plug-in to the correct directory
- That's all
As indicated at the end of Importing 3D models section in the user's guide, you can also get the libraries folder when you click on any SH3F file listed in the Furniture libraries section of the Libraries in use pane. The latter pane is displayed by clicking on the Libraries... button shown at the bottom of Sweet Home 3D About dialog box.
rdorsch
Post by rdorsch »
Thanks for your replies and many thanks for the explanation with the .etreks directory (I looked for .sweethome3d before).
I assume sweethome3D never writes into the furniture sh3f files, i.e. symlinks would also work.
Rainer
