I'm new on this...
The rooms I have created doesn't have ceiling...In fact when I render the 3D snapshot, the light of the sun comes from above...
I have already created a second floor in order to "make" the ceiling but nothing happens...
Anyone can help me?
Regards!
How to make the ceiling visible....?
This topic has been viewed 8216 times and has 3 replies
Re: How to make the ceiling visible....?
If you look from the outside into a room the ceiling is visible only when using the virtual visitor.
If you create a second floor, that floor needs to have a floor. In aerial view, you will then see the floor, not the ceiling.
Thanks Hans!
I have already make a second floor and well, the ceiling appears. Strangenly, when I activate the virtual visit, I have to active the 2nd Floor (where is the floor that is the ceiling on the 1rst Floor) in order to see the ceiling on the 1st floor.
thanks!
thanks!
When you do a right click in the 3D preview window there is an option to show just the selected level, or all levels.
