Landscaping
This topic has been viewed 25837 times and has 18 replies
Landscaping
I have fallen in love with sweethome3d!! I may have found a new career modeling peoples houses for them.
I am buying a new house and until I can move in sometime in March, I am virtually living there in my mocked up model thanks to you!
However, I have a question now that my model is built: is it possible to work "underground"?
One side of my house is level with the ground, but on the other side, the basement is exposed.
Is there a way to model the earth so that my house is even but the earth slopes away?
Thanks!
Thanks!
Re: Landscaping
Searching around in the forum, you should find several threads discussing terrain and landscape. E.g. threads 4817, 6060, SourceForge 3d models ticket 299 and so on. Long and short of it is that you need to use negative level elevation and/or geometric shapes around your house. But some more looking around will probably give you other examples too. ok
Re: Landscaping
thanks...i tried searching for "landscapes" but didn't return what I needed.
Re: Landscaping
This is exactly what I need to do: http://www.sweethome3d.com/support/foru ... hread,6060
But I'm baffled as to how to go about it.
I can create the triangles, but it's having the almost opposite effect that I need.
How is the green "grid" below the triangle in the above thread contouring to the bottom of the triangle?
Also, the triangles in the sourceforge link are "upside down" from my needs...how can I flip them?
Re: Landscaping
wait...I think i get it....
1 giant green triangle larger than my terrain, then a flipped upside-down triangle under the base of my house with appropriate texture on it's sides?
Re: Landscaping
Well - there is sort of a disclaimer saying that SH3D is not really landscaping software. So do not expect it to happen automatically...
That said, it is possible to create a landscape around your creation. Exactly how, depends on whether you need a basement or not. It seems you are in an explorer phase - in which case you may not need to read on.
If you are not going to have a basement (negative elevation on the lowest levels), you can just use a triangle (or some other shape) for your terrain (giant triangle).
But a triangle will be visible in the lower levels, so if you need a basement, you need to put your triangles (or other shapes) AROUND the foundation to simulate the terrain.
Here is a, maybe not very elegant (but relatively simple), way of doing it: template_scandinavian.sh3d.
Note that you may want to play with levels (and in-between levels) in addition to some shapes (SF models 299 ) around the house.
Re: Landscaping
Is it possible to flip one of those triangles upside down?
I can only find rotate and "mirror", but that isn't what I need currently.
thanks
thanks
Re: Landscaping
What you want to do is rotate the triangle model at the point you import it into SH3D. Use the arrows at the stage of importing shown in screen two in this section of the user's guide until the triangle is aligned properly. Name the object something like "Triangle (upside down)" so it's easier to differentiate in the inventory list.Is it possible to flip one of those triangles upside down?
Re: Landscaping
During import (only) you can flip (rotate) the object with the green arrows in the second step. Press Shift to rotate by single degrees. ok
Re: Landscaping
Thanks to you fine people, I was able to make this!!
http://imgur.com/XbLbZ8X
Now all I need to figure out is how to put on a roof!
