How to make a horizontal tube
This topic has been viewed 4145 times and has 3 replies
Wmatilda
Post by Wmatilda »
Hi all,
Please Help!! I'm desperate to know how to make a horizontal pipe/tube?
Thanks in advance..
Re: How to make a horizontal tube
Import the cylinder from the free models page - rotate to horizontal during import (green arrows). Scale to correct size. ok
Wmatilda
Post by Wmatilda »
Thanks for your help. How can I make this cylinder hollow?
Well, it is hollow already... but if you want to open the ends you can set top and bottom to invisible (requires newest 5.2) - but as the inside has not texture - it may not give the effect you want.
Which means you are probably better off trying the cylinder shared by Ceciliabr in thread 6462 - that should be open ended.
