Hi everyone
I'm a new Sweet Home user and I enjoy it.
During my fist project I have encounterd a couple of challanges which I'm sure you can help me with.
1. When I started to draw the top level, how do I add one below?
2. How can I create a roof?
3. How can I creat a wall which starts at the sealing(if you have a room which a part of it is sloped)?
Thanks in advanced for your help
Chvermont
Drawing issues
This topic has been viewed 7257 times and has 2 replies
Re: Drawing issues
Double-click the tab on the new level and insert the correct elevations/floor thickness and ceiling height (for each level).1. When I started to draw the top level, how do I add one below?
If you look ah the FAQ and in the forum you will find hints, e.g. thread 6372 has some links to start you off.2. How can I create a roof?
If you modify a wall, it is a question of setting start and end heights. Often you will first need to split the wall first. ok3. How can I creat a wall which starts at the sealing(if you have a room which a part of it is sloped)?
Re: Drawing issues
Thanks for your quick response.
This helped a lot.
I keep on trying?
This helped a lot.
I keep on trying?
