sweethome3d-4.6-linux-x64.tgz
This topic has been viewed 12136 times and has 11 replies
bertaudmarc
Post by bertaudmarc »
I started with ./SweetHome3d, the splash screen is displayed and the application hang:
java.lang.RuntimeException: cannot load system cursor: CopyDrop.32x32
	at sun.awt.X11.XToolkit.lazilyLoadDesktopProperty(Unknown Source)
Caused by: java.lang.RuntimeException: failed to load system cursor: DnD.Cursor.CopyDrop : cannot load system cursor: CopyDrop.32x32
	at java.awt.dnd.DragSource.load(Unknown Source)
bertaudmarc
Re: sweethome3d-4.6-linux-x64.tgz
I tried to add the following option:
-Dcom.eteks.sweethome3d.no3D=true
but no effect.
The option you tried disables the 3D view, but the error you've got isn't bound to any 3D feature. I think the file you downloaded is buggy? Did you try to download Sweet Home 3D again?
bertaudmarc
I tried the 2D version according to the FAQ suggestion !
I think the error is bound to java
bertaudmarc
Could you suggest me a reliable link to download sweethome3d-4.6-linux-x64.tgz !
Use the links in Download page.
bertaudmarc
That was my source !
I downloaded again, uncompressed in another folder, executed it but always the same error.
Problem of graphic driver ? (mga200 is very old ...)
Try to search your error in Google. You might have interesting answers like this one.
bertaudmarc
I solved the problem like this:
I modified the mgag200 option to 0 in the modesetting.conf file !
But I lost high resolution of my screen ...
Many thanks to Emmanuel.
Thanks for your feedback.
In the future version of Sweet Home 3D, there are some chances that under Linux and Windows, there will be an update of the version of Java3D, the library used for the 3D view. Please, try again once it will be released to see if it works better.
