Wall (Стены)
This topic has been viewed 8848 times and has 4 replies
ELITE83
Wall (Стены)
Post by ELITE83 »
Hello. Thanks for a great, convenient and simple program!!
Have one request - to improve the mechanism of work with walls.
Now the walls you can set the height on the edges and get a beveled wall.
Please add 2 more options:
1) to set the height above the floor - this will allow you to make beams and other elements above the floor
2) to set the height above the floor for the beginning and end walls - then the mechanism of the walls to help to make virtually any geometric shape in space and immediately solve the complex problem of attics and ceilings
/translation from Russian/
Здравствуйте. Спасибо за отличную, удобную и простую программу!!
Есть одна просьба - доработать механизм работы со стенами.
Сейчас стенам можно задать высоту по краям и получить скошенную стену.
Пожалуйста добавьте еще 2 настройки:
1) задавать высоту над полом - это позволит делать балки и другие элементы выше пола
2) задавать высоту над полом для начала и конца стены - тогда механизм стен позволить сделать практически любую геометрическую фигуру в пространстве и сразу решит проблему сложных мансард и перекрытий
Re: Wall (Стены)
Sorry this won't happen. It would make the program too complicate.
If you want to elevate a wall, put it on an upper level.
If you want to create a hole in wall, use an invisible shape at its bottom.
If you want to draw a complicate shape, use an other software, or draw more than one wall, or draw a room at an upper level.
ELITE83
Re: Wall (Стены)
Post by ELITE83 »
maybe I haven't translated into English.
I offer quite a bit to finalize the walls, so you can not only make the slope of the wall, lift the edge of the wall 1
This is already enough to make many complex elements!
ELITE83
Re: Wall (Стены)
Post by ELITE83 »
now
please add
raise in the beginning and raise at the end
Re: Wall (Стены)
Yes, I would love that !!
People have been asking this for many years...
