Hi!
I've downloaded the portable version (4.5) os sweet home 3d, since it appears to work without JAVA installed in my system.
However when I start the app, it claims to install JAVA SE 6.
How can I fix this? (I don't want to install JAVA on my system)
I'm running OS X 10.9.5
Thank you!
4.5 Portable Version asking por JAVA in MAC OS
This topic has been viewed 5763 times and has 4 replies
Re: 4.5 Portable Version asking por JAVA in MAC OS
In the case of Mac OS X, it requires to install Java 6. If you don't want to install it, then don't use the portable version.
Thanks for the response.
Is there any version bundled with java?
By the way, congrats for the app!!
A free version bundled with Java doesn't exist under Mac OS X yet, but I really don't see the problem to install Apple Java 6. Mac OS X 10.9 used to propose to install Java 6 after user confirmation, while Mac OS X 10.10 makes it less easy by sending the user to a page where he can download Java 6. Installing Java 6 won't put your computer at risk, since it can be used only for applications and not for applets in web browsers which encountered some security problems in the past years. I could bundled Oracle Java 7 or 8 like I did for the Mac App Store version, but creating one application able to switch between Oracle Java and Apple Java depending on the environment isn't easy. Maybe in the next version...
Ok, thank you very much!
