SW3D stuck on startup...please help
This topic has been viewed 3222 times and has 2 replies
soho2000
Post by soho2000 »
hi everybody,
i was working on a quite big plan...and from time to time the software jammed...restarting Sweethome3D helped... now i am stuck...because when the software opens it tries to re-open the last file and instantly get stuck again...
what can i do?
are there auto-save files to delete somewhere?
please give me a hint=)
Re: SW3D stuck on startup...please help
The folder where recovered files are stored depends on your system:
- Under Windows Vista / 7 / 8, it's C:\Users\user\AppData\Roaming\eTeks\Sweet Home 3D\recovery folder
- Under Windows XP and previous versions of Windows, it's C:\Documents and Settings\user\Application Data\eTeks\Sweet Home 3D\recovery folder
- Under Mac OS X, it's the Library/Application Support/eTeks/Sweet Home 3D/recovery subfolder of your user folder
- Under Linux, it's .eteks/sweethome3d/recovery subfolder of your user folder
- With the portable version, it's data/recovery subfolder of Sweet Home 3D folder.
Did you try to increase the max memory to see if it works better?
soho2000
Post by soho2000 »
Merci! Emmanuel;)
i managed to get rid of the faulty recovery file which caused the problem.
put the RAM value to 4096... can´t tell if performance is better, doesn´t feel better... my machine is a 2012 hackintosh 24GB RAM for Videoediting (Premiere and AE) GPU with CUDA support
but its working=) yay=)
