I'm using SH 4.3 with Java on XP SP3. No problems using my design, making a video or making a picture. When I try printing, the preview doesn't work nor does Print to PDF because the file that's being printed is empty with what I can see. When I try to print to a printer it prints the furniture list and nothing else. On my screen I have everything, 3D Image and drawing also.
Everything is checked to be printed in the Page Setup and of course the printer is working just fine ...
I tried printing each item individually (3D, Drawing etc) but it still didn't work. Its as if it doesn't recognize my drawing or 3D image !!
When I created my drawing, I just started adding walls and never created a room. Could this be the problem ?
I can email anyone the drawing if they would like and try it out ??
Printing problems !
This topic has been viewed 3071 times and has 5 replies
Re: Printing problems !
Csaba,
Everything worked fine on my computer.
I sent you 3 PDF's.
I sent you 3 PDF's.
As explained in the FAQ Sweet Home 3D refuses to print the 3D view. What can I do?, it must be a graphics card driver issue.
In case you can't solve the issue, you can still make some screen captures.
As explained in the original post, not even the drawing will print alone ... I have 4GB of RAM ! I didn't think that the drawing only was considered 3D
If you read the FAQ, you'll see it's not a problem of RAM but a problem of video driver.
