I can't find a way to draw the room (floor) inside a room that has a wall with a 90-degree arc. Can someone help me with this?
Thank you so much!
Newbie: How do I draw a room to match a wall with an arc?
This topic has been viewed 3885 times and has 3 replies
- carlos_spork
- Country: Hurlingham, Buenos Aires, Argentina
Re: Newbie: How do I draw a room to match a wall with an arc?
Carlos,
To draw a room, choose the Room button, then double-click inside your room.
If that doesn´t work, the walls of your room aren´t closed. Make sure that all walls are connected, or edit the X,Y coordinates so that the end of one wall has the same coordinates as the start of the next wall.
- carlos_spork
Thank you so much, Hans! I didn't know about the double-click feature to create a room. In my case, the walls weren't closed anyway. I also noticed that, in the end, it's just a matter of "connecting the dots", so I just added additional dots to make it look a bit better when zooming-in in the 3D-view.
Again, thank you!
Again, thank you!
- carlos_spork
By the way, Hans, this is an example of what I was trying to achieve: Gravel access-path
