Newbie: How do I draw a room to match a wall with an arc?
This topic has been viewed 3644 times and has 3 replies
carlos_spork
Country: Hurlingham, Buenos Aires, Argentina
Post by carlos_spork »
I can't find a way to draw the room (floor) inside a room that has a wall with a 90-degree arc. Can someone help me with this?
Thank you so much!
Re: Newbie: How do I draw a room to match a wall with an arc?
Carlos,
To draw a room, choose the Room button, then double-click inside your room.
If that doesn´t work, the walls of your room aren´t closed. Make sure that all walls are connected, or edit the X,Y coordinates so that the end of one wall has the same coordinates as the start of the next wall.
carlos_spork
Thank you so much, Hans! I didn't know about the double-click feature to create a room. In my case, the walls weren't closed anyway. I also noticed that, in the end, it's just a matter of "connecting the dots", so I just added additional dots to make it look a bit better when zooming-in in the 3D-view.
Again, thank you!
carlos_spork
By the way, Hans, this is an example of what I was trying to achieve: Gravel access-path
