Bonjour, j'ai un problème avec SH3d, le programme se ferme tout seul et un fichier log s'affiche sur mon bureau, y a t-il un problème avec Java ?
le fichier est nommé " hs_err_pid5940.log "
le descriptif du fichier :
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x07eb2e53, pid=5940, tid=3376
# JRE version: 7.0_11-b21
# Java VM: Java HotSpot(TM) Client VM (23.6-b04 mixed mode, sharing windows-x86 )
# Problematic frame:
# C [ig4icd32.dll+0x12e53]
# Failed to write core dump. Minidumps are not enabled by default on client versions of Windows
# http://bugreport.sun.com/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
--------------- T H R E A D ---------------
Current thread (0x04ffa800): JavaThread "J3D-Renderer-1" [_thread_in_native, id=3376, stack(0x09200000,0x09250000)]
siginfo: ExceptionCode=0xc0000005, reading address 0x0000000c
Registers:
EAX=0x00000000, EBX=0x0a968901, ECX=0x09f69540, EDX=0x08b560b8
ESP=0x0924eb24, EBP=0x0001803f, ESI=0x0a96df10, EDI=0x09f69540
EIP=0x07eb2e53, EFLAGS=0x00010202
Top of Stack: (sp=0x0924eb24)
0x0924eb24: 00000000 74654701 00786950 726f466c
0x0924eb34: 08c10080 0aa02e68 07eb362c 0001803f
0x0924eb44: 08c10080 09e23a68 07eb325e 00000000
0x0924eb54: 09f69540 08c10080 09e23a68 0835cbae
0x0924eb64: 0a8a6f28 087a6c0b 08c10080 09e23a68
0x0924eb74: 0a9689c0 0aa02e68 00000000 0a9689c0
0x0924eb84: 00c10080 0835f75e 0001803f 00000001
0x0924eb94: 0a7dd7e0 0a7dd7e0 00000000 0924ebc0
Instructions: (pc=0x07eb2e53)
0x07eb2e33: c6 44 24 0b 00 74 09 33 c0 5e 83 c4 24 c2 08 00
0x07eb2e43: 8b 44 24 2c 8b 4c 24 30 85 c0 75 04 85 c9 74 e7
0x07eb2e53: 8b 50 0c 53 55 8b 69 1c 57 8b 78 1c 89 54 24 24
0x07eb2e63: 89 4c 24 20 c7 44 24 18 00 00 00 00 90 80 7c 24
Register to memory mapping:
EAX=0x00000000 is an unknown value
EBX=0x0a968901 is an unknown value
ECX=0x09f69540 is an unknown value
EDX=0x08b560b8 is an unknown value
ESP=0x0924eb24 is pointing into the stack for thread: 0x04ffa800
EBP=0x0001803f is an unknown value
ESI=0x0a96df10 is an unknown value
EDI=0x09f69540 is an unknown value
Stack: [0x09200000,0x09250000], sp=0x0924eb24, free space=314k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
j javax.media.j3d.NativePipeline.useCtx(JJJ)Z+0
j javax.media.j3d.NativePipeline.useCtx(Ljavax/media/j3d/Context;JLjavax/media/j3d/Drawable;)Z+43
j javax.media.j3d.Canvas3D.useCtx(Ljavax/media/j3d/Context;JLjavax/media/j3d/Drawable;)Z+6
j javax.media.j3d.Canvas3D.makeCtxCurrent(Ljavax/media/j3d/Context;JLjavax/media/j3d/Drawable;)V+51
J javax.media.j3d.Renderer.doWork(J)V
J javax.media.j3d.J3dThread.run()V
v ~StubRoutines::call_stub
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
0x0d1ba800 JavaThread "pool-13-thread-2" [_thread_blocked, id=6244, stack(0x0b830000,0x0b880000)]
0x04ffb400 JavaThread "pool-6-thread-1" [_thread_blocked, id=4900, stack(0x05ea0000,0x05ef0000)]
0x0af53c00 JavaThread "J3D-InputDeviceScheduler-2" [_thread_blocked, id=5336, stack(0x0b940000,0x0b990000)]
0x0af53400 JavaThread "J3D-SoundSchedulerUpdateThread-2" [_thread_blocked, id=4780, stack(0x0b9b0000,0x0ba00000)]
0x0af53000 JavaThread "J3D-RenderStructureUpdateThread-2" [_thread_blocked, id=5740, stack(0x0b730000,0x0b780000)]
0x0af52800 JavaThread "J3D-BehaviorScheduler-2" [_thread_blocked, id=5484, stack(0x0b880000,0x0b8d0000)]
0x0af52000 JavaThread "J3D-TransformStructureUpdateThread-2" [_thread_blocked, id=4480, stack(0x0a1c0000,0x0a210000)]
0x04ffa400 JavaThread "J3D-RenderingEnvironmentStructureUpdateThread-2" [_thread_blocked, id=5684, stack(0x0a3e0000,0x0a430000)]
0x04ff5c00 JavaThread "J3D-SoundStructureUpdateThread-2" [_thread_blocked, id=7092, stack(0x0b6b0000,0x0b700000)]
0x04ff9c00 JavaThread "J3D-GeometryStructureUpdateThread-2" [_thread_blocked, id=4184, stack(0x0b450000,0x0b4a0000)]
0x04ff9400 JavaThread "J3D-BehaviorStructureUpdateThread-2" [_thread_blocked, id=5488, stack(0x0b600000,0x0b650000)]
0x0ac84000 JavaThread "J3D-MasterControl-2" [_thread_blocked, id=2488, stack(0x0a280000,0x0a2d0000)]
0x0ac83c00 JavaThread "J3D-NotificationThread" [_thread_blocked, id=4380, stack(0x066b0000,0x06700000)]
0x0ac83400 JavaThread "J3D-TimerThread" [_thread_blocked, id=5236, stack(0x0a730000,0x0a780000)]
0x0ac83000 JavaThread "J3D-RenderingAttributesStructureUpdateThread" [_thread_blocked, id=6432, stack(0x0a230000,0x0a280000)]
0x0ac80800 JavaThread "pool-8-thread-4" [_thread_blocked, id=4256, stack(0x09b70000,0x09bc0000)]
0x0ac81000 JavaThread "pool-8-thread-3" [_thread_blocked, id=5288, stack(0x05aa0000,0x05af0000)]
0x0ac67800 JavaThread "pool-8-thread-2" [_thread_blocked, id=2480, stack(0x08e10000,0x08e60000)]
0x0ac65c00 JavaThread "pool-8-thread-1" [_thread_blocked, id=5424, stack(0x09b20000,0x09b70000)]
0x0ac66c00 JavaThread "pool-7-thread-4" [_thread_blocked, id=5284, stack(0x096c0000,0x09710000)]
0x0ac66000 JavaThread "pool-7-thread-3" [_thread_blocked, id=2504, stack(0x095c0000,0x09610000)]
0x0ac67400 JavaThread "pool-7-thread-2" [_thread_blocked, id=6364, stack(0x05180000,0x051d0000)]
0x0ac66800 JavaThread "pool-7-thread-1" [_thread_blocked, id=5268, stack(0x08d40000,0x08d90000)]
0x0ac82400 JavaThread "Thread-23" [_thread_blocked, id=7152, stack(0x0e4a0000,0x0e4f0000)]
0x0ac82800 JavaThread "pool-2-thread-8" [_thread_blocked, id=5604, stack(0x0e450000,0x0e4a0000)]
0x04ff5800 JavaThread "pool-2-thread-7" [_thread_blocked, id=3956, stack(0x0a390000,0x0a3e0000)]
0x0ac81c00 JavaThread "Swing-Shell" daemon [_thread_blocked, id=2088, stack(0x0e1c0000,0x0e210000)]
0x0ac81400 JavaThread "pool-5-thread-1" [_thread_blocked, id=6312, stack(0x0e240000,0x0e290000)]
0x0ac64800 JavaThread "pool-2-thread-6" [_thread_blocked, id=3780, stack(0x09550000,0x095a0000)]
0x0ac64000 JavaThread "pool-2-thread-5" [_thread_blocked, id=4472, stack(0x08db0000,0x08e00000)]
0x04ffc800 JavaThread "pool-2-thread-4" [_thread_blocked, id=7064, stack(0x06da0000,0x06df0000)]
0x04ffc000 JavaThread "pool-2-thread-3" [_thread_blocked, id=6108, stack(0x09350000,0x093a0000)]
0x04ffbc00 JavaThread "pool-2-thread-2" [_thread_blocked, id=5116, stack(0x06c50000,0x06ca0000)]
0x04ff7800 JavaThread "pool-2-thread-1" [_thread_blocked, id=2260, stack(0x05fd0000,0x06020000)]
0x04ffb000 JavaThread "autoSaveTimer" daemon [_thread_blocked, id=4228, stack(0x07c40000,0x07c90000)]
=>0x04ffa800 JavaThread "J3D-Renderer-1" [_thread_in_native, id=3376, stack(0x09200000,0x09250000)]
0x04ff9000 JavaThread "Thread-17" daemon [_thread_in_native, id=6684, stack(0x05dd0000,0x05e20000)]
0x04ff8800 JavaThread "Timer-2" daemon [_thread_blocked, id=5520, stack(0x06bb0000,0x06c00000)]
0x04ff7c00 JavaThread "Timer-1" daemon [_thread_blocked, id=3380, stack(0x07c90000,0x07ce0000)]
0x04ff8400 JavaThread "TimerQueue" daemon [_thread_blocked, id=1104, stack(0x06090000,0x060e0000)]
0x04ff7000 JavaThread "AWT-EventQueue-0" [_thread_in_native, id=6920, stack(0x06c00000,0x06c50000)]
0x04ff6800 JavaThread "TimerQueue" daemon [_thread_blocked, id=4980, stack(0x06700000,0x06750000)]
0x04ff6400 JavaThread "AWT-EventQueue-1" [_thread_blocked, id=6980, stack(0x06660000,0x066b0000)]
0x04ff5000 JavaThread "AWT-Shutdown" [_thread_blocked, id=612, stack(0x06570000,0x065c0000)]
0x002bd800 JavaThread "DestroyJavaVM" [_thread_blocked, id=5992, stack(0x023a0000,0x023f0000)]
0x04f4c400 JavaThread "Javaws Secure Thread" daemon [_thread_blocked, id=6788, stack(0x05b40000,0x05b90000)]
0x04f46800 JavaThread "AWT-Windows" daemon [_thread_in_native, id=5068, stack(0x02400000,0x02500000)]
0x04f45c00 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=6732, stack(0x04d40000,0x04d90000)]
0x04f2d800 JavaThread "CacheCleanUpThread" daemon [_thread_blocked, id=6688, stack(0x057f0000,0x05840000)]
0x04f29000 JavaThread "CacheMemoryCleanUpThread" daemon [_thread_blocked, id=6696, stack(0x054f0000,0x05540000)]
0x04e9f000 JavaThread "traceMsgQueueThread" daemon [_thread_blocked, id=6832, stack(0x04a70000,0x04ac0000)]
0x0235b800 JavaThread "Service Thread" daemon [_thread_blocked, id=6820, stack(0x04e20000,0x04e70000)]
0x02343800 JavaThread "C1 CompilerThread0" daemon [_thread_blocked, id=6816, stack(0x04d90000,0x04de0000)]
0x02342000 JavaThread "Attach Listener" daemon [_thread_blocked, id=6748, stack(0x04ca0000,0x04cf0000)]
0x0233f000 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=1596, stack(0x04ba0000,0x04bf0000)]
0x0231d400 JavaThread "Finalizer" daemon [_thread_blocked, id=4144, stack(0x04ad0000,0x04b20000)]
0x0231bc00 JavaThread "Reference Handler" daemon [_thread_blocked, id=2956, stack(0x00520000,0x00570000)]
Other Threads:
0x0231a800 VMThread [stack: 0x048c0000,0x04910000] [id=5768]
0x04e80c00 WatcherThread [stack: 0x05130000,0x05180000] [id=6812]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
def new generation total 157248K, used 47329K [0x144d0000, 0x1ef70000, 0x1ef70000)
eden space 139776K, 30% used [0x144d0000, 0x16ea5398, 0x1cd50000)
from space 17472K, 25% used [0x1de60000, 0x1e2c32a8, 0x1ef70000)
to space 17472K, 0% used [0x1cd50000, 0x1cd50000, 0x1de60000)
tenured generation total 349568K, used 212660K [0x1ef70000, 0x344d0000, 0x344d0000)
the space 349568K, 60% used [0x1ef70000, 0x2bf1d318, 0x2bf1d400, 0x344d0000)
compacting perm gen total 12800K, used 12785K [0x344d0000, 0x35150000, 0x384d0000)
the space 12800K, 99% used [0x344d0000, 0x3514c5d8, 0x3514c600, 0x35150000)
ro space 10240K, 42% used [0x384d0000, 0x38910ce0, 0x38910e00, 0x38ed0000)
rw space 12288K, 54% used [0x38ed0000, 0x39550e30, 0x39551000, 0x39ad0000)
Card table byte_map: [0x046b0000,0x047e0000] byte_map_base: 0x0460d980
Polling page: 0x00230000
Code Cache [0x026b0000, 0x02f88000, 0x046b0000)
total_blobs=4490 nmethods=4052 adapters=370 free_code_cache=23726Kb largest_free_block=24295552
Compilation events (10 events):
Event: 401.683 Thread 0x02343800 4046 com.eteks.sweethome3d.viewcontroller.PlanController::isItemResizable (17 bytes)
Event: 401.683 Thread 0x02343800 nmethod 4046 0x02f81f88 code [0x02f82090, 0x02f8218c]
Event: 401.727 Thread 0x02343800 4047 java.util.ArrayList::<init> (55 bytes)
Event: 401.727 Thread 0x02343800 nmethod 4047 0x02f82208 code [0x02f82320, 0x02f82428]
Event: 401.739 Thread 0x02343800 4048 javax.swing.JTable::getColumnCount (10 bytes)
Event: 401.739 Thread 0x02343800 nmethod 4048 0x02f824c8 code [0x02f825d0, 0x02f82800]
Event: 401.740 Thread 0x02343800 4049 javax.swing.JTable::getCellRect (350 bytes)
Event: 401.741 Thread 0x02343800 nmethod 4049 0x02f82908 code [0x02f82ad0, 0x02f83424]
Event: 401.741 Thread 0x02343800 4050 java.text.DecimalFormat::<init> (131 bytes)
Event: 401.741 Thread 0x02343800 nmethod 4050 0x02f84088 code [0x02f841d0, 0x02f84530]
GC Heap History (10 events):
Event: 376.794 GC heap before
{Heap before GC invocations=233 (full 99):
def new generation total 157248K, used 145925K [0x144d0000, 0x1ef70000, 0x1ef70000)
eden space 139776K, 100% used [0x144d0000, 0x1cd50000, 0x1cd50000)
from space 17472K, 35% used [0x1cd50000, 0x1d351598, 0x1de60000)
to space 17472K, 0% used [0x1de60000, 0x1de60000, 0x1ef70000)
compacting perm gen total 12800K, used 12783K [0x344d0000, 0x35150000, 0x384d0000)
the space 12800K, 99% used [0x344d0000, 0x3514be58, 0x3514c000, 0x35150000)
Event: 376.802 GC heap after
Heap after GC invocations=234 (full 99):
def new generation total 157248K, used 5905K [0x144d0000, 0x1ef70000, 0x1ef70000)
eden space 139776K, 0% used [0x144d0000, 0x144d0000, 0x1cd50000)
from space 17472K, 33% used [0x1de60000, 0x1e424548, 0x1ef70000)
Event: 380.996 GC heap before
{Heap before GC invocations=234 (full 99):
def new generation total 157248K, used 145682K [0x144d0000, 0x1ef70000, 0x1ef70000)
from space 17472K, 33% used [0x1de60000, 0x1e424ad0, 0x1ef70000)
Event: 381.004 GC heap after
Heap after GC invocations=235 (full 99):
def new generation total 157248K, used 5700K [0x144d0000, 0x1ef70000, 0x1ef70000)
from space 17472K, 32% used [0x1cd50000, 0x1d2e1250, 0x1de60000)
Event: 381.005 GC heap before
{Heap before GC invocations=235 (full 99):
def new generation total 157248K, used 11160K [0x144d0000, 0x1ef70000, 0x1ef70000)
eden space 139776K, 3% used [0x144d0000, 0x14a24f18, 0x1cd50000)
Event: 381.012 GC heap after
Heap after GC invocations=236 (full 99):
def new generation total 157248K, used 5699K [0x144d0000, 0x1ef70000, 0x1ef70000)
from space 17472K, 32% used [0x1de60000, 0x1e3f0f10, 0x1ef70000)
Event: 385.218 GC heap before
{Heap before GC invocations=236 (full 99):
def new generation total 157248K, used 145476K [0x144d0000, 0x1ef70000, 0x1ef70000)
from space 17472K, 32% used [0x1de60000, 0x1e3f1100, 0x1ef70000)
the space 12800K, 99% used [0x344d0000, 0x3514be88, 0x3514c000, 0x35150000)
Event: 385.226 GC heap after
Heap after GC invocations=237 (full 99):
def new generation total 157248K, used 5736K [0x144d0000, 0x1ef70000, 0x1ef70000)
from space 17472K, 32% used [0x1cd50000, 0x1d2ea1f8, 0x1de60000)
Event: 399.181 GC heap before
{Heap before GC invocations=237 (full 99):
def new generation total 157248K, used 145513K [0x144d0000, 0x1ef70000, 0x1ef70000)
from space 17472K, 32% used [0x1cd50000, 0x1d2ea570, 0x1de60000)
the space 12800K, 99% used [0x344d0000, 0x3514c5c8, 0x3514c600, 0x35150000)
Event: 399.189 GC heap after
Heap after GC invocations=238 (full 99):
def new generation total 157248K, used 4492K [0x144d0000, 0x1ef70000, 0x1ef70000)
Deoptimization events (0 events):
No events
Internal exceptions (10 events):
Event: 279.352 Thread 0x0d1b9c00 Threw 0x199f2c68 at C:\jdk7u1_32P\jdk7u11\hotspot\src\share\vm\prims\jvm.cpp:2846
Event: 294.028 Thread 0x0d1b9c00 Threw 0x344d05b8 at C:\jdk7u1_32P\jdk7u11\hotspot\src\share\vm\gc_interface/collectedHeap.inline.hpp:171
Event: 294.223 Thread 0x0d1b9000 Threw 0x1a427db0 at C:\jdk7u1_32P\jdk7u11\hotspot\src\share\vm\prims\jvm.cpp:2846
Event: 300.332 Thread 0x04ff7000 Threw 0x1a88ef80 at C:\jdk7u1_32P\jdk7u11\hotspot\src\share\vm\prims\jni.cpp:742
Event: 317.726 Thread 0x04ff7000 Threw 0x1c5c9628 at C:\jdk7u1_32P\jdk7u11\hotspot\src\share\vm\prims\jni.cpp:742
Event: 317.745 Thread 0x04ff7000 Threw 0x1c5d7ad0 at C:\jdk7u1_32P\jdk7u11\hotspot\src\share\vm\prims\jvm.cpp:1166
Event: 317.745 Thread 0x04ff7000 Threw 0x1c5d8280 at C:\jdk7u1_32P\jdk7u11\hotspot\src\share\vm\prims\jvm.cpp:1166
Event: 317.745 Thread 0x04ff7000 Threw 0x1c5d87c8 at C:\jdk7u1_32P\jdk7u11\hotspot\src\share\vm\prims\jvm.cpp:1166
Event: 317.745 Thread 0x04ff7000 Threw 0x1c5da068 at C:\jdk7u1_32P\jdk7u11\hotspot\src\share\vm\prims\jvm.cpp:1166
Event: 352.081 Thread 0x04ff7000 Threw 0x14c2a198 at C:\jdk7u1_32P\jdk7u11\hotspot\src\share\vm\prims\jni.cpp:742
Events (10 events):
Event: 381.005 Executing VM operation: GenCollectFull
Event: 381.012 Executing VM operation: GenCollectFull done
Event: 385.217 Executing VM operation: GenCollectForAllocation
Event: 385.217 Executing VM operation: GenCollectForAllocation done
Event: 385.218 Executing VM operation: GenCollectFull
Event: 385.226 Executing VM operation: GenCollectFull done
Event: 399.180 Executing VM operation: GenCollectForAllocation
Event: 399.181 Executing VM operation: GenCollectForAllocation done
Event: 399.181 Executing VM operation: GenCollectFull
Event: 399.189 Executing VM operation: GenCollectFull done
Dynamic libraries:
0x00090000 - 0x000bf000 C:\Program Files (x86)\Java\jre7\bin\javaw.exe
0x77010000 - 0x77190000 C:\Windows\SysWOW64\ntdll.dll
0x75990000 - 0x75aa0000 C:\Windows\syswow64\kernel32.dll
0x76480000 - 0x764c7000 C:\Windows\syswow64\KERNELBASE.dll
0x75aa0000 - 0x75b40000 C:\Windows\syswow64\ADVAPI32.dll
0x75e90000 - 0x75f3c000 C:\Windows\syswow64\msvcrt.dll
0x764d0000 - 0x764e9000 C:\Windows\SysWOW64\sechost.dll
0x76660000 - 0x76750000 C:\Windows\syswow64\RPCRT4.dll
0x746f0000 - 0x74750000 C:\Windows\syswow64\SspiCli.dll
0x746e0000 - 0x746ec000 C:\Windows\syswow64\CRYPTBASE.dll
0x75d70000 - 0x75e70000 C:\Windows\syswow64\USER32.dll
0x75ce0000 - 0x75d70000 C:\Windows\syswow64\GDI32.dll
0x74a50000 - 0x74a5a000 C:\Windows\syswow64\LPK.dll
0x75f40000 - 0x75fdd000 C:\Windows\syswow64\USP10.dll
0x73780000 - 0x7391e000 C:\Windows\WinSxS\x86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.7601.17514_none_41e6975e2bd6f2b2\COMCTL32.dll
0x74a90000 - 0x74ae7000 C:\Windows\syswow64\SHLWAPI.dll
0x74b00000 - 0x74b60000 C:\Windows\system32\IMM32.DLL
0x74980000 - 0x74a4c000 C:\Windows\syswow64\MSCTF.dll
0x72dc0000 - 0x72e7e000 C:\Program Files (x86)\Java\jre7\bin\msvcr100.dll
0x6a860000 - 0x6abac000 C:\Program Files (x86)\Java\jre7\bin\client\jvm.dll
0x71f40000 - 0x71f47000 C:\Windows\system32\WSOCK32.dll
0x76440000 - 0x76475000 C:\Windows\syswow64\WS2_32.dll
0x763a0000 - 0x763a6000 C:\Windows\syswow64\NSI.dll
0x71f80000 - 0x71fb2000 C:\Windows\system32\WINMM.dll
0x76fe0000 - 0x76fe5000 C:\Windows\syswow64\PSAPI.DLL
0x72f90000 - 0x72f9c000 C:\Program Files (x86)\Java\jre7\bin\verify.dll
0x72d80000 - 0x72da0000 C:\Program Files (x86)\Java\jre7\bin\java.dll
0x707f0000 - 0x70932000 C:\Program Files (x86)\Java\jre7\bin\awt.dll
0x74750000 - 0x747df000 C:\Windows\syswow64\OLEAUT32.dll
0x75fe0000 - 0x7613c000 C:\Windows\syswow64\ole32.dll
0x719f0000 - 0x71a70000 C:\Windows\system32\uxtheme.dll
0x72da0000 - 0x72db3000 C:\Program Files (x86)\Java\jre7\bin\zip.dll
0x71dd0000 - 0x71e29000 C:\Program Files (x86)\Java\jre7\bin\deploy.dll
0x739b0000 - 0x739b9000 C:\Windows\system32\VERSION.dll
0x75b40000 - 0x75c5b000 C:\Windows\syswow64\WININET.dll
0x76140000 - 0x76143000 C:\Windows\syswow64\Normaliz.dll
0x76150000 - 0x76309000 C:\Windows\syswow64\iertutil.dll
0x764f0000 - 0x76601000 C:\Windows\syswow64\urlmon.dll
0x74c20000 - 0x7586a000 C:\Windows\syswow64\SHELL32.dll
0x745e0000 - 0x745eb000 C:\Windows\system32\profapi.dll
0x72d20000 - 0x72d34000 C:\Program Files (x86)\Java\jre7\bin\net.dll
0x71eb0000 - 0x71eec000 C:\Windows\system32\mswsock.dll
0x6b180000 - 0x6b186000 C:\Windows\System32\wship6.dll
0x72f80000 - 0x72f8f000 C:\Program Files (x86)\Java\jre7\bin\nio.dll
0x712a0000 - 0x712b3000 C:\Windows\system32\dwmapi.dll
0x70790000 - 0x70798000 C:\Windows\system32\Secur32.dll
0x6abe0000 - 0x6ac24000 C:\Windows\system32\dnsapi.DLL
0x6af10000 - 0x6af2c000 C:\Windows\system32\iphlpapi.DLL
0x71ea0000 - 0x71ea7000 C:\Windows\system32\WINNSI.DLL
0x6af00000 - 0x6af05000 C:\Windows\System32\wshtcpip.dll
0x6ac50000 - 0x6ac77000 C:\Program Files (x86)\Common Files\Microsoft Shared\Windows Live\WLIDNSP.DLL
0x6aef0000 - 0x6aef6000 C:\Windows\system32\rasadhlp.dll
0x75870000 - 0x7598e000 C:\Windows\syswow64\CRYPT32.dll
0x74af0000 - 0x74afc000 C:\Windows\syswow64\MSASN1.dll
0x73010000 - 0x73026000 C:\Windows\system32\CRYPTSP.dll
0x72fc0000 - 0x72ffb000 C:\Windows\system32\rsaenh.dll
0x745f0000 - 0x74607000 C:\Windows\system32\USERENV.dll
0x6ac40000 - 0x6ac50000 C:\Windows\system32\NLAapi.dll
0x72d70000 - 0x72d80000 C:\Windows\system32\napinsp.dll
0x72d50000 - 0x72d62000 C:\Windows\system32\pnrpnsp.dll
0x72d40000 - 0x72d48000 C:\Windows\System32\winrnr.dll
0x72d10000 - 0x72d1d000 C:\Windows\system32\wshbth.dll
0x72cd0000 - 0x72d08000 C:\Windows\System32\fwpuclnt.dll
0x72ca0000 - 0x72cca000 C:\Program Files (x86)\Java\jre7\bin\fontmanager.dll
0x71d90000 - 0x71dc1000 C:\Program Files (x86)\Java\jre7\bin\t2k.dll
0x74b60000 - 0x74be3000 C:\Windows\syswow64\CLBCatQ.DLL
0x6b1b0000 - 0x6b2ab000 C:\Windows\system32\WindowsCodecs.dll
0x71ad0000 - 0x71b1c000 C:\Windows\system32\apphelp.dll
0x70a10000 - 0x70a41000 C:\Windows\system32\EhStorShell.dll
0x747e0000 - 0x7497d000 C:\Windows\syswow64\SETUPAPI.dll
0x74bf0000 - 0x74c17000 C:\Windows\syswow64\CFGMGR32.dll
0x75e70000 - 0x75e82000 C:\Windows\syswow64\DEVOBJ.dll
0x72e80000 - 0x72f75000 C:\Windows\system32\PROPSYS.dll
0x6b640000 - 0x6b6b0000 C:\Windows\system32\ntshrui.dll
0x6b6f0000 - 0x6b709000 C:\Windows\system32\srvcli.dll
0x71ef0000 - 0x71efb000 C:\Windows\system32\cscapi.dll
0x72c90000 - 0x72c9a000 C:\Windows\system32\slc.dll
0x10000000 - 0x1000e000 C:\Users\ROSSI\AppData\Local\Temp\extension7538690714729507254.dll
0x70940000 - 0x70a08000 C:\Windows\system32\OPENGL32.dll
0x70a60000 - 0x70a82000 C:\Windows\system32\GLU32.dll
0x6b550000 - 0x6b637000 C:\Windows\system32\DDRAW.dll
0x71f10000 - 0x71f16000 C:\Windows\system32\DCIMAN32.dll
0x71f00000 - 0x71f07000 C:\Windows\system32\atiglpxx.dll
0x07ea0000 - 0x08c01000 C:\Windows\system32\ig4icd32.dll
0x71d80000 - 0x71d8b000 C:\Windows\system32\atigktxx.dll
0x6b490000 - 0x6b546000 C:\Windows\system32\aticfx32.dll
0x71d70000 - 0x71d76000 C:\Program Files (x86)\Java\jre7\bin\jawt.dll
0x05070000 - 0x05099000 C:\Users\ROSSI\AppData\Local\Temp\extension6382547714607128798.dll
0x707c0000 - 0x707e4000 C:\Program Files (x86)\Java\jre7\bin\dcpr.dll
0x73920000 - 0x739a4000 C:\Windows\WinSxS\x86_microsoft.windows.common-controls_6595b64144ccf1df_5.82.7601.17514_none_ec83dffa859149af\comctl32.dll
0x744e0000 - 0x74501000 C:\Windows\system32\ntmarta.dll
0x76610000 - 0x76655000 C:\Windows\syswow64\WLDAP32.dll
0x6a3d0000 - 0x6a568000 C:\Windows\system32\NetworkExplorer.dll
0x6ae90000 - 0x6aebe000 C:\Windows\System32\shdocvw.dll
0x6acb0000 - 0x6acc2000 C:\Windows\system32\MPR.dll
0x71a70000 - 0x71a78000 C:\Windows\System32\drprov.dll
0x744b0000 - 0x744d9000 C:\Windows\System32\WINSTA.dll
0x707a0000 - 0x707b4000 C:\Windows\System32\ntlanman.dll
0x70340000 - 0x70357000 C:\Windows\System32\davclnt.dll
0x70a50000 - 0x70a58000 C:\Windows\System32\DAVHLPR.dll
0x6b6e0000 - 0x6b6ef000 C:\Windows\system32\wkscli.dll
0x6f9a0000 - 0x6f9a9000 C:\Windows\system32\netutils.dll
0x65050000 - 0x65288000 C:\Windows\system32\wpdshext.dll
0x712c0000 - 0x71450000 C:WindowsWinSxSx86_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.7601.17825_none_72d273598668a06
b\gdiplus.dll
0x6ae00000 - 0x6ae89000 C:\Windows\system32\PortableDeviceApi.dll
0x763b0000 - 0x763dd000 C:\Windows\syswow64\WINTRUST.dll
0x6ad80000 - 0x6adbf000 C:\Windows\system32\audiodev.dll
0x66690000 - 0x668f7000 C:\Windows\system32\WMVCore.DLL
0x6adc0000 - 0x6adfd000 C:\Windows\system32\WMASF.DLL
0x6aec0000 - 0x6aee2000 C:\Windows\system32\EhStorAPI.dll
0x6b480000 - 0x6b489000 C:\Windows\system32\LINKINFO.dll
0x6ace0000 - 0x6ad80000 C:\Windows\system32\SearchFolder.dll
0x6b6d0000 - 0x6b6df000 C:\Windows\system32\samcli.dll
0x6b6b0000 - 0x6b6c2000 C:\Windows\system32\SAMLIB.dll
0x6a830000 - 0x6a855000 C:\Program Files (x86)\Java\jre7\bin\jpeg.dll
0x6a800000 - 0x6a82d000 C:\Program Files (x86)\Java\jre7\bin\kcms.dll
0x0cfd0000 - 0x0d0bb000 C:\Windows\system32\dbghelp.dll
VM Arguments:
jvm_args: -Xmx512m -Dcom.eteks.sweethome3d.deploymentInformation=Java Web Start -Dcom.eteks.sweethome3d.applicationId=SweetHome3D#JavaWebStart -Dcom.eteks.sweethome3d.lazyParts=SweetHome3D Loader3DS FreeHep SunFlow JMF iText Java3D -Djnlp.application.href=http://www.sweethome3d.com/SweetHome3D.jnlp -Xbootclasspath/a:C:\\Program Files (x86)\\Java\\jre7\\lib\javaws.jar;C:\\Program Files (x86)\\Java\\jre7\\lib\deploy.jar;C:\\Program Files (x86)\\Java\\jre7\\lib\plugin.jar -Djnlpx.vmargs=-Xmx512m "-Dcom.eteks.sweethome3d.deploymentInformation=Java Web Start" -Dcom.eteks.sweethome3d.applicationId=SweetHome3D#JavaWebStart "-Dcom.eteks.sweethome3d.lazyParts=SweetHome3D Loader3DS FreeHep SunFlow JMF iText Java3D" -Djnlp.application.href=http://www.sweethome3d.com/SweetHome3D.jnlp -Djnlpx.jvm=C:\Program Files (x86)\Java\jre7\bin\javaw.exe -Djnlpx.splashport=49254 -Djnlpx.home=C:\\Program Files (x86)\\Java\\jre7\\bin -Djnlpx.remove=false -Djnlpx.offline=true -Djnlpx.relaunch=true -Djnlpx.session.data=C:\Users\ROSSI\AppData\Local\Temp\session1705999500218181728 -Djnlpx.heapsize=-1,536870912 -Djava.security.policy=file:C:\\Program Files (x86)\\Java\\jre7\\lib\security\javaws.policy -DtrustProxy=true -Xverify:remote -Dsun.awt.warmup=true
java_command: com.sun.javaws.Main -secure -notWebJava C:\Users\ROSSI\AppData\LocalLow\Sun\Java\Deployment\cache\6.0\52\247e2df4-2e1a7434
Launcher Type: SUN_STANDARD
Environment Variables:
PATH=C:\Program Files (x86)\Java\jre7\bin;C:\Program Files (x86)\HP SimplePass 2012\;C:\Program Files (x86)\AMD APP\bin\x86_64;C:\Program Files (x86)\AMD APP\bin\x86;C:\Program Files\Common Files\Microsoft Shared\Windows Live;C:\Program Files (x86)\Common Files\Microsoft Shared\Windows Live;C:Windowssystem32;C:Windows;C:WindowsSystem32Wbem;C:WindowsSystem32WindowsPowerShellv
1.0\;C:\Program Files (x86)\Windows Live\Shared;C:\Program Files (x86)\ATI Technologies\ATI.ACE\Core-Static;C:\Program Files (x86)\Intel\Services\IPT\;C:\Program Files (x86)\CineForm\Tools;C:\Program Files (x86)\GoPro\Tools;"C:\Program Files (x86)\Java\jre7\bin"
USERNAME=ROSSI
OS=Windows_NT
PROCESSOR_IDENTIFIER=Intel64 Family 6 Model 42 Stepping 7, GenuineIntel
--------------- S Y S T E M ---------------
OS: Windows 7 , 64 bit Build 7601 Service Pack 1
CPU:total 4 (2 cores per cpu, 2 threads per core) family 6 model 42 stepping 7, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ssse3, sse4.1, sse4.2, popcnt, avx, ht, tsc, tscinvbit
Memory: 4k page, physical 6238064k(2893720k free), swap 12474268k(8809200k free)
vm_info: Java HotSpot(TM) Client VM (23.6-b04) for windows-x86 JRE (1.7.0_11-b21), built on Jan 12 2013 02:19:22 by "java_re" with unknown MS VC++:1600
time: Thu Apr 18 00:39:46 2013
elapsed time: 401 seconds
quelqu'un a une solution , merci pour votre lumière.
problème le programme se ferme tout seule avec un fichier .log sur mon bureau
This topic has been viewed 4941 times and has 2 replies
Re: problème le programme se ferme tout seule avec un fichier .log sur mon bureau
J'espère que les solutions proposées dans la FAQ résoudront votre problème.
Merci pour votre réponse, je vais essayer les modifications de ma carte graphique.
