Incorrect import 3DS model
This topic has been viewed 8516 times and has 8 replies
sergeynn
Country: Russia
Post by sergeynn »
Hi.
I try to import in sweethome3d this model, which is in 3DS format.
But in sweethome3d this model looks doubled
Please, help me to import correct model.
Re: Incorrect import 3DS model
It seems to be the same issue as the one mentioned in the FAQ The 3D view of Sweet Home 3D is always black or shows twice the same image. What can I do?
Could you try if the proposed solution works for you?
The model imports more or less correctly on my computer.
Problems:
- no textures;
- windows aren't transparent;
- imported model looks different from pictured model.
This is a known problem with models from this website.
sergeynn
Country: Russia
Post by sergeynn »
In my case, only this model shows twince. Other models (also from this site) shows normally. And 3D view of sweethome is normal. I use sweethome in Linux.
Who can convert this model to another format fo me?
I also use Linux (Ubuntu 12.04), so it's not a Linux problem, but a problem of your computer.
sergeynn
Country: Russia
Post by sergeynn »
Hans, if your computer import this model correctly, can you save it to another format which i can import correctly?
No, I can't.
As I wrote, there are several problems with the model, most importantly that the glass isn't transparent. So, what use would windows be, if you can't see through them??
sergeynn
Country: Russia
Post by sergeynn »
So, if it don't work, i do so.
2 different model - window and door.
Window i have done.
Now i need door.
But i can't find door wich is from 2 section - top and bottom. Top section is transparent, bottom is not transparent.
Does anybody have door model which i need?
Americans call this a Dutch door when you can open top and bottom half separately.
Or else search for a door with glass pane.
A bit of fantasy goes a long way...
