How To Make Roof ?
This topic has been viewed 140913 times and has 13 replies
00turkey
Country: İstanbul, Pendik, Türkiye
How To Make Roof ?
Post by 00turkey »
I Am very very bad english, expression is picture please :)
My Question : How To Make A Roof ?
Allready Thanks :)
Re: How To Make Roof ?
Please read the FAQ How can I create a roof on top of a house?
00turkey
Post by 00turkey »
thankss :D
Mo
Country: Germany
Post by Mo »
Hi, I'm new. Learning how to create rooms was quite easy. But the creation of roofs even with this tutorial is still a hard job.
Are there any plans to improve the roof creation for next versions?
I managed the part of the tutorial until page 9 where I used the "Copy as new furniture"-plugin and pasted. But I don't get the roof pasted to the walls and I don't get the triangles created like that.
For our project the most important is creating the room dimensions of our little house. I could work without roof, but actually to get a real impression it would be important to add a roof.
As explained in the FAQ, Sweet Home 3D doesn't support the creation of roofs until now, and the proposed tutorial gives some workarounds found by Hans, a super user of Sweet Home 3D.
I plan to add a tool to create some roofs in a future version but sorry, this probably won't happen before months.
Mo
Country: Germany
Post by Mo »
Hi. I guess the new 4.0 version did not give any progress for roofs?
Currently I feel like SweetHome3D(SH3D) is good for flats and multi-stage flats, but not for houses. I deliberated long for which tool I would use for planning the house. Professional ones like Catia V5 (not mentioning the price of course) can do all detailed stuff for 3D, but when it comes to furnishing SH3D is a very quick approach, and portable, which was the main reason for me having Linux/Windows, and even different archs up to Linux on PPC.
What is the current state for house environments such as gardens? So far I have only seen some trees to arrange, but it should not be that hard to arrange all different types of plants on a plain map, when the models are there.
No, maybe in a coming version...
Keep in mind that Sweet Home 3D first targets interior design.
Gardens would require some "terra forming" tool to give the various elevation points of the ground, and more models of plants and trees. This kind of 3D models are complicate to design, so it will take probably years before a complete library of this kind appears, according to contributors proposals.
amechax
Country: Njombe, Non-US/Non-Canadian, Tanzania
Post by amechax »
I have made triangles out of red slate roof designed by Emmanuel Puybaret find them here
I 'll improve it over time
Strikkie
Country: Hooffdorp, Noord holland, Holland
Post by Strikkie »
When I follow the tutorial and I create a a room the drawing is on the height of the groundfloor but I can not get it on the level of the roof, how can I change the height of the layer?
HawkDawg
Country: Georgia, USA
Post by HawkDawg »
To get a room on a different level than the ground floor you have to add a level, which is found under the Plan tab. When you add a level you can set it's height in that settings window.
You can also adjust the height of the new level later under the Plan tab again by selecting Modify level.
Hawk
