PLAN>Modify walls
This topic has been viewed 4306 times and has 6 replies
cicliced
PLAN>Modify walls
Post by cicliced »
I have just started using this program and am getting on fine with it apart from there seems to be a few menu options greyed out on the menu, specifically 'PLAN>MODIFY WALLS', so i'm unable to edit the floor colour etc.
Any ideas why this might be?
Thanks
James
Re: PLAN>Modify walls
1 - You have to select a wall, before you can modify it.
2 - To edit a floor, you first have to draw a room, then you can edit it with Modify room.
Maybe it's a good idea to read the User's guide first?
cicliced
Post by cicliced »
Hi Hans,
Sorry I meant to say specifically 'MODIFY ROOMS' is greyed out in the menu, so I can't access it. I have created 1 room. The plan is unlocked.
Thanks
James
You have to select first the rooms you want to modify. If you want to change them, select all, it's not a problem if the selection contains other kinds of objects.
cicliced
Post by cicliced »
Hi Emmanuel, I have selected the rooms but it still doesn't let me have access to 'modify rooms'. See screen print below...
Am I selecting it correctly? Do all the walls have to be 'joined'? it looks like all the walls are joined apart from one wall that just overlaps at the corner and won't connect to the other wall.
Thanks
James
cicliced
Post by cicliced »
Here is the link to the file i created if you want to have a look at it.
https://docs.google.com/open?id=0B6ErAv ... TltazZIRWc
You have to click 'file'>'download' at the top left of the screen.
cicliced
Post by cicliced »
i solved it, i didn't have the room corners set, i was just drawing on the initial screen that opened.
