Right click 'Modify Wall' on 'wall' and 'popup dialog' does not appear.
Click again and there is no response.
screenshot : https://i0.wp.com/www.dolzikoo.com/wp-c ... C720&ssl=1
OS: windows 10 64bit.
cant not open, 'modify walls...' dialogue
This topic has been viewed 3323 times and has 4 replies
Re: cant not open, 'modify walls...' dialogue
Could you check if there's some error log that could explain your issue?
Please open a cmd window and run Sweet Home 3D redirecting errors to a file with a command like:
If the file log.txt contains something, please post it here.
"C:\Program Files\Sweet Home 3D\SweetHome3D.exe" 2> Desktop\log.txtEmmanuel Puybaret, Sweet Home 3D creator
I am also facing the same problem ...
I get that log.txt file after I launch sweet home 3d by command prompt ....as you said..
The log file you posted reports an error in the look and feel, and I'm not sure I can fix that.
Please, try to use a different Windows theme, or run Sweet Home 3D with a different look and feel by adding a file named [font=courier new]SweetHome3D.l4j.ini[/font] in the same folder as [font=courier new]SweetHome3D.exe[/font] and writing the following line in it (with the starting hyphen):
Hope this will work...
-Dswing.defaultlaf=javax.swing.plaf.metal.MetalLookAndFeelEmmanuel Puybaret, Sweet Home 3D creator
