adding 2 or more imported textures
This topic has been viewed 2556 times and has 3 replies
Does anyone know if it is possible to add more than 1 texture per wall? i.e. If I want to make a design on a wall with tiles made of pictures that I import.[url=mailto:[email protected]][email protected][/url]
Re: adding 2 or more imported textures
You can add a thin box along the wall and apply a texture on it, or create a special texture as explained in this document.
Ami,
When you use version 3.4 you can add a Level. Give the wall on the lower level a different colour or texture than the wall on the upper level.
Thank you guys, I will test it out.
