I export an object in .obj from DAZ Studio.
I get: .obj, .mtl files and texture file in a MAP folder.
I 'zip' them all.
I import it into SH3D (and put it in the library).
Everything is ok when rendered.
I save, close and reopen the SH3D file: my object appears now 'white' (no more textures).
If I put on scene a new instance of my object from the library, this instance has the right textures... and lose them if I save, close and reopen the file...
Any idea ?
Thank you.
Phil
Lost textures when reopening a file with .obj imported piece of furniture
This topic has been viewed 2572 times and has 2 replies
Re: Lost textures when reopening a file with .obj imported piece of furniture
Texture images are not supposed to be in a subfolder of the folder where the OBJ and MTL files are.I get: .obj, .mtl files and texture file in a MAP folder.
To fix this issue, remove texture images from MAP subfolder and edit MTL file to remove the text "MAP/" or "MAP\".
Thank you Emmanuel.
It works like a charm now!
Thank you also for the pleasure we feel using this wonderful product.
Phil
Phil
