Looking for construction libraries and symbols
This topic has been viewed 13235 times and has 10 replies
Mystic_fool
I need more staircase configurations, and electrical symbols. Are these available from Sweet Home 3D, or is there somewhere I can download them from?
Thanks
Thanks
Mystic_fool
Re: Looking for construction libraries and symbols
Forgot to mention, I'm using a Mac.
Didn't you find what you're looking for among all the models and link in the 3D models import page?
Mystic_fool
No. What's really needed is a variety of simple staircase configurations, that will show detail in 2D, and hopefully work in 3D as well. A lot of the staircases available on the 3D model page, do not show any detail in 2D, they just look like rectangles boxes, plus there are not enough configurations.Didn't you find what you're looking for among all the models and link in the 3D models import page?
Example of what I'm looking for:
Mystic_fool
I get error messages when I try to use any Google Sketchup files with Sweet Home 3D. Am I missing something here?
Check the Google Sketchup Warehouse for all your needs...
If necessary install Sketchup to convert models from SKP to DAE format.
Mystic_fool
Thanks, I was able to figure out how to convert SKP to DAE, using Google Sketchup. Question though, I don't see much use in a whole page of electrical symbols. There's no way to separate any one symbol, for use in floor plans. I'm I missing something here?Check the Google Sketchup Warehouse for all your needs...
Thanks
In Sketchup you can easily use Edit -> Group -> Explode to ungroup the symbols, then delete all but one, and export it as DAE. Then Undo the deletion and save another symbol you need.
Mystic_fool
Thanks, I was able to separate symbols, but the quality was such, that they will not work for blueprints. Not sure if there is anything that can be done about that.In Sketchup you can easily use Edit -> Group -> Explode to ungroup the symbols, then delete all but one, and export it as DAE. Then Undo the deletion and save another symbol you need.
