Question about 3DS rendering
This topic has been viewed 5119 times and has 7 replies
LucasRey
Post by LucasRey »
Hello people I'm a new (and happy) user of Sweet Home 3D...
For sure I'm a newbie user and I've a little problem with 3DS object rendering. I downloaded many models from the Archive3D site, but all the time I've problem with rendering.
For example from this model: http://archive3d.net/?a=download&id=33954
If I import into Sweet Home 3D this is the result :-(
http://img130.imageshack.us/img130/3734/image002n.png
Could someone help me?
Re: Question about 3DS rendering
Lucas,
Best thing you can try is import the model into Blender, than export ot from there as an OBJ file.
LucasRey
Post by LucasRey »
Thanks Hans for interesting approach.
Btw, I tried to import/export my previous example model, but nothing changes. Maybe I have to use also the texture contains into the zip file...
OK it's to hard for me, since I never use a cad, drawing or rendering application! Probably I'll use the default models! :-)
db4tech
Country: UK
Post by db4tech »
Hi Lucas,
I also found, many of the models on archive3d.net are not as they appear in the sample download image. Many are corrupt and textures are present but not applied.
When starting out, there are many good models on Sweet Home 3D model page or try Google 3D warehouse, thanks to Emmanuel the ones in Collada format can be imported into Sweet Home 3D.
Thanks,
David
There are many nice columns in the Sketchup Warehouse. Start your Warehouse search with filetype:zip and you will get only models that can be directly imported in SH3D.
LucasRey
Post by LucasRey »
Guys, thanks for Google 3D warehouse tips!
I've still texture problem with some Collada models coming from Google, but in general all appear fine.
Hans could you please clarify: "Start your Warehouse search with filetype:zip and you will get only models that can be directly imported in SH3D." ???
Or better, give me an example? I don't understant what are you saying! :-(
Lucas,
1 - Warehouse search
Try this query: filetype:zip column
Select the image that interests you, and click it.
Now underneath the preview image, pull down the Download Image menu, and you will see that the last format offered is the Collada (.zip) format.
2 - Collade texture problems
See this thread (the one of April 12, 9:23 PM).
LucasRey
Post by LucasRey »
Perfect Hans, now is clear!
Thank you for all your help!
