Floor Rendering Problem
This topic has been viewed 19750 times and has 21 replies
wrosun
Country: Pokhara, Nepal
Post by wrosun »
Hello! friends
Here is a problem i observed,The problrm is about creating floors.
if a single floor(room) is created for whole house then it appears while rendering but if diffenent floors are created then only the floor which is created at first is seen while rendering [:-/]
I dont hink i explained well so here are some pictures to show what i mean
IN THIS ONE I USED COLOR/DEFAULT TEXTURES/USER MADE TEXTURE
AS YOU CAN SEE NON OF THESE WORK OUT.
Re: Floor Rendering Problem
It's probably the same problem as macfrog.
I never saw it happen yet.
Can you send [url=mailto:[email protected]]me[/url] your wrong SH3D files please?
wrosun,
I tried to copy this behaviour but without success. I copied your designs exactly, created the first room in the same place, I used four imported textures. and applied textures to the walls. It renders perfectly in aerial view and virtual visitor view.
Can you check the size of the images you use for your textures? Not only how big the file is (in Kb) but also the size in pixels.
Hans I don't think it's a matter of size. From the screen captures, even some texture images coming from Sweet Home 3D (256x256 pixels) aren't displayed.
wrosun
Post by wrosun »
well this is a file i created in 5 min to show you guys and any model i create shows same problem.
Yup it is same problem as MACFROG. First i thought it was some thing he did but i tries it and when ever i make models shows the problem.
@HANS:
This problem is same if i create room in other places at first only that room shows floor .I dont think its is pixel problem hans because when i use default textures only also then there is the same problem and if i create first room using user texture then the rooms will show texture while rendering...
@puybaret:
I will attach a sh3d file showing the problem,File
I have done every thing but the problem is always there. [>:)]
Too bad, I don't have any problem to render the file you posted at the 2 best quality levels.
If I can't reproduce the problem, I won't be easy to fix. [:(]
From you screen captures, I see you tried to compute the images with the Advanced rendering plug-in. Could you try with Sweet Home 3D default photo creation dialog? I don't think it will change anything for you, since macfrog used this dialog too, but who knows what can happen with furtive bugs?
wrosun,
Thanks for the file. On my computer (operating system is Ubuntu 10.10) they render perfectly.
wrosun
Post by wrosun »
Really? well i havent tried it with Ubuntu. My operating system is Windows 7 home premium if you can try with it once some how then may be you will see the problem....can there be problem with my computer???
No I don't think so.
On my side, I tried under Windows 7 and Mac OS X successfully.
By the way, wrosun, your avatar looks nice. [;)]
wrosun
Post by wrosun »
@Puybaret:
May be i should have told you before that the rendering with default photo creation dialogue works perfectly in any quality mode.I am having problems in advanced rendering plug-in.
Thanks! [:D]
