Problem with the second floor's floor in 3D view
This topic has been viewed 4162 times and has 1 replies
konstantinos4
Post by konstantinos4 »
When I try to make a two-storey house, the second floors's floor is invisible (in 3D view) .
I know that there are two buttons for each floor (on the top of the compass) in order to see how the proccess of each floor is going. When I press the 'Level 0' button, the first floor only is apperaed in 3D view. Although, when I press the 'Level 1' button, the two floors are appeared at the same time (in 3D view), with the first floor on the botom and the second floor on the top.
Pressing the 'Level 1' buttom, the two floors are appeared without something between them in order to make clear that the two floors are seperated from each other. Also, the furnitures that are placed on the second floor are illustrated like they're on the air. I think that the Sweet Home 3D must have a layer/floor or something between the two storeys in order to seperate them better.
picture of a two-storey house pressin the 'Level 1' button : Image
sjb007
Re: Problem with the second floor's floor in 3D view
Post by sjb007 »
You need to add a room to the second level. Activate the Create rooms icon, or use Ctrl+Shift+R. Then double click inside the walls on Level 1. That will create the floor that will sit between the levels. In fact, looking at your image, it looks like you haven't added the room on Level 0 either.
