Resize entire plan
This topic has been viewed 8966 times and has 3 replies
edice
Resize entire plan
Post by edice »
I built my sweethome plan by tracing my house plans.
Now, after some measuring of the house, I release the original scale was not correct (or the plans weren't correct), and the whole house is a little bit too big.
Is there a way I can resize the entire house by a percentage?
thanks
Paul
maker
Re: Resize entire plan
Post by maker »
As far as I can see, the only way is to export as OBJ.
Open in Wings3d or similar program.
Scale it there.
Import as furniture.
But maybe someone can come up with a better idea
Good luck ;-)
starrunner
Post by starrunner »
You could use this new plugin:
Advanced plan editing
It has the resize action, you are searching for.
After installing you just need to select all items in the plan ([Ctrl]+[A]) and open the resize dialog in Edit->Resize.
Paps72
Post by Paps72 »
Why don`t Import as a new Furniture, and make it there bigger, or smaller???
That is possible, when you exmport the Project (or maybe splitted in parts) as .OBJ (Must all parts been marked, or that, what you want to resize/copy).
Best way, I make it, with the "Copy as new Furniture" Plug in.
But before, check the size of the walls!
Maybe walls to slim?!
Users browsing this forum: DuckDuckGo [Bot], Google [Bot], MSN [Bot]
