Hi all,
I have been using SweetHome3d to replicate my new house and work on some renovations.
When I replicated the floorplan I didn't notice that CM was being used as the unit and I scaled everything in MM.
Now I am having issues when adding windows, doors etc.
Is there a way to select the entire project and pretty much divide it by 10 so to convert all measures from MM to CM?
I have installed Advanced Editor and I see the resize option, when I do use it though the walls are all stack up on each other, I am not sure if I am doing something wrong or is just not supposed to be used for this purpose.
All help is greatly appreciated
Resize entire project
This topic has been viewed 1898 times and has 2 replies
Re: Resize entire project
It's hard to say what you have to do: so many variables, and not much info. Indeed, the AdvancedEditor is the tool to use.
WHAT you have to change depends on what is incorrect. Suggestion: make a backup of your plans and work on that file to see what needs to be done.
1 - check height of levels and thickness of floors
2 - check height of walls
3 - check length of walls
4 - check size of furniture (doors & windows are furniture)
Where it says "check" you should read "check and if necessary correct by multiplying or dividing by 10". When changing furniture make sure you put a checkmark in "Keep proportions".
Thanks for the reply, I tried again and realized that after executing only the thickness of the wall wasn't resized, so I just manually changed the value of each wall and it all was correctly positioned after that, thank you
