Tip: lock the layout in Sweet Home 3D first, then test finishes on a photo of the real room
This topic has been viewed 321 times and has 2 replies
claudialandy_hd
Post by claudialandy_hd »
A common snag when planning a renovation in Sweet Home 3D: the layout and dimensions come out right, but the finishes never look like the real room. A two-step workflow that separates the two jobs can help.
Step 1: do everything dimensional in Sweet Home 3D
  • Draw the walls from measured numbers, not from the estate agent's plan. Measure each wall at floor height and again at 1 m, because old walls are rarely square.
  • Put in doors and windows with their real swing and sill height. Open the doors in the 3D view to check that none of them hits a radiator or a wardrobe.
  • Use the furniture list to give every item its real width, depth and height. A sofa that is 10 cm too deep is what ruins most layouts.
  • Check walkways in the top view. Keep at least 80 to 90 cm clear on main routes.
  • Save one version per layout idea (v1-sofa-window, v2-sofa-wall) so you can compare later.
This is where Sweet Home 3D is really strong: it is precise, it is quick to change, and nothing you do in it is a guess about size.
Step 2: stop asking the 3D view to answer style questions
The default textures and the light in the 3D view are fine for understanding space, but it is hard to judge whether a sage wall goes with your actual oak floor and the light from your actual window. Models in the 3D view tend to look cleaner and colder than the real room.
So once the layout is decided, take a wide photo of the real room, from the doorway, in daylight, and test the finishes on that photo instead: wall colour, floor, curtains, rug. A photo-based tool is one way to do this step. We make one, an AI interior design tool that restyles an uploaded room photo while keeping the walls, windows and layout. It keeps the structure of the photo, so you can compare, for example, a warm white against a greige on the same wall in the same light. It does not know dimensions, so do not use it for sizes. That is what step 1 is for.
What each tool is good for
  • Sweet Home 3D: sizes, clearances, door swings, furniture counts, quantities for a shopping list.
  • A photo-based preview: colour, material, mood, and how the room feels in its real light.
  • A tape measure: the final check on anything you are about to buy.
A few small habits that help
  • Export a few top views as images and print them. It is much easier to talk to a builder with a plan on paper than with a screen.
  • Name furniture items after the real product (for example, "sofa 210x95 grey") so the shopping list is useful later.
  • When you share a model on the forum for help, add the room dimensions in the post. People will answer much faster.
An open question for the forum: how do you connect a Sweet Home 3D plan with what the finished room will look like? Lighting seems the hardest part, for example making the 3D view match a north-facing room. If you have a method that works, I would be glad to hear it.
GaudiGalopin3324
Country: Russia
Re: Tip: lock the layout in Sweet Home 3D first, then test finishes on a photo of the real room
Post by GaudiGalopin3324 »
Aggressive AI implementation has begun. I want to warn all SH3D users. Read the proposed texts from these SELLERS very carefully. The main problem is that they engage in substitution. They combine completely incompatible concepts in one text. They write perfectly correct recommendations for completely different processes that have nothing to do with their platforms. Please note: first, the recommendations are about SH3D, and the second part is a circus‑like operation involving a real room. Where does this real room come from when the design is being carried out in SH? If you don’t understand where the deception is, it’s easy to take the wrong path and start doing ordinary circus tricks and magic. This has nothing to do with designing in SH3D. And sellers like the author of the thread pretend that everything is fine and shamelessly provide a link to a paid resource from the circus arena. Please be careful with such advice. To actually use AI in your work and not feel deceived, you need to start doing everything in SH3D and stick with the program until the end. Only it is honest. AI manipulates your feelings and expectations and deceives you. You get a false sense of your own talent without any effort. For this reason alone, AI should always be secondary. Ideally, you shouldn’t use AI at all. I use it)) :roll: , because I fundamentally understand what’s most important here. But I warn you that the SELLER and the author of this topic is completely indifferent to the fate of SH3D. Registration today and one topic. Classic spam. But I agree that ignoring the powerful tool that is AI is also foolish and short‑sighted.
MarioSambol
Country: Croatia
Post by MarioSambol »
I agree with the comment about AI. It’s not really about AI creativity; its capability is limited to replacing existing elements. I’m not sure how it handles a completely empty room—it likely generates something, but then tends to produce very similar variations. It’s probably useful for the actual rendering of a space: you create the space in SH3D, generate a basic render, and then use AI to produce a final render. Perhaps it should be viewed as a tool, rather than a creative force.
