Crash after Java update
This topic has been viewed 7371 times and has 9 replies
Hello everyone.
I installed SweetHome3d 2.3 a few days ago. Everything was just fine. After Java software update program started to crash with no errors, warnings, exceptions etc. in the following situation:
- start the program;
- hide 3d view panel by clicking on the arrow on separator (program could crash, but not every time);
- then hide the furniture panel by clicking on the arrow on separator - program crashes every time.
I updated graphic drivers to the latest version, but it did not solve the problem.
Here is my system description:
- Windows Vista 32;
- ATI Radeon HD 2400 PRO (8.712.0.0 2010-03-02);
- Java 1.6 update 19 (build 1.6.0_19-b04).
Can anyone help me to solve the problem?
Thank you very much in advance.
- Windows Vista 32;
Re: Crash after Java update
You may have the same problem as the one described in this bug. [:(]
Could you hide the navigation arrows with preferences and confirm whether it still crashes or not?
First, thank you for reply.
I hide 3d navigation arrows (Preferences dialog) and after that hiding 3d panel and furniture panel goes without any problems. When I select to show the 3d navigation arrows, program crashes again. So, I can solve the problem that way, but I think this is a kind of a bug
And one more thing - when I start the program dialog box appears, saying that "Program requested to go online. Ok | Cancel" If I select "Cancel" program will not start. I did not get that message before. What if I do not have an Internet connection?
I know that the question is not about 3d stuff, but still ...
I have the same problem on Fedora 12. The solution is the same - hide 3d navigation arrows via preferences dialog.
Could you post the Java crash report you got (it's a file named hs_err_pid####.log)?
This should help Java 3D team to fix this bug.
of course I could, but I do not know where to find it
so, if you tell me where to find the crash report I will send it ... and I do not know where to send it
so, tell me please where I can find the crash report and where I can send it to. I think I can do it then
Pau:
Every operating system has a SEARCH function that you can use to fin files on your hard disk. It's just an idea.
The crash report is a text file. Simply copy paste its content in a message of this thread.
Thank you for your help.
Here is a crash report (C:\Windows\System32\hs_err_pid2352.log):
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x08664dcd, pid=2352, tid=508
# JRE version: 6.0_19-b04
# Java VM: Java HotSpot(TM) Client VM (16.2-b04 mixed mode, sharing windows-x86 )
# Problematic frame:
# C [extension105815763305391408.dll+0x4dcd]
# http://java.sun.com/webapps/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
--------------- T H R E A D ---------------
Current thread (0x06c95800): JavaThread "J3D-Renderer-1" [_thread_in_native, id=508, stack(0x07ff0000,0x08040000)]
siginfo: ExceptionCode=0xc0000005, reading address 0xfffffffc
Registers:
EAX=0xffffffff, EBX=0x00000000, ECX=0xffffffff, EDX=0x00000000
ESP=0x0803f7a0, EBP=0x00000000, ESI=0x049159e0, EDI=0x08b79578
EIP=0x08664dcd, EFLAGS=0x00210246
Top of Stack: (sp=0x0803f7a0)
0x0803f7a0: 06c95800 34278d60 0803f854 34278d60
0x0803f7b0: 00000001 00000011 0803f860 0803f828
0x0803f7c0: 0803f854 01f72603 01f78269 34278d60
0x0803f7d0: 0803f8a4 0803f7dc 01f725d7 01f79f47
0x0803f7e0: 06c95910 0803f8a4 08b79578 00000000
0x0803f7f0: 00000000 00000000 0000003c 00000000
0x0803f800: 0000003c 00000001 00000400 00000001
0x0803f810: 00000290 00000004 ffffffff 0803f86c
Instructions: (pc=0x08664dcd)
0x08664dbd: 51 e8 2d eb ff ff 8b 97 b0 02 00 00 8b 44 24 78
0x08664dcd: 8b 04 82 85 c0 89 44 24 7c 75 24 a1 b4 3c 71 08
Stack: [0x07ff0000,0x08040000], sp=0x0803f7a0, free space=13d0803f2d4k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
[error occurred during error reporting (printing native stack), id 0xc0000005]
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
j javax.media.j3d.NativePipeline.texturemapping(JIIIIIIIIIII[BII)V+0
j javax.media.j3d.NativePipeline.texturemapping(Ljavax/media/j3d/Context;IIIIIIIIIII[BII)V+32
j javax.media.j3d.Canvas3D.texturemapping(Ljavax/media/j3d/Context;IIIIIIIIIII[BII)V+30
j javax.media.j3d.J3DGraphics2DImpl.copyDataToCanvas(IIIIIIII)V+188
j javax.media.j3d.J3DGraphics2DImpl.doFlush()V+227
j javax.media.j3d.J3DGraphics2DImpl.flush(Z)V+52
j com.eteks.sweethome3d.swing.HomeComponent3D$1.canvas3DPostRendered(Ljavax/media/j3d/Canvas3D;)V+31
j com.eteks.sweethome3d.j3d.Component3DManager$1.postRender()V+12
j javax.media.j3d.Renderer.doWork(J)V+6111
j javax.media.j3d.J3dThread.run()V+19
v ~StubRoutines::call_stub
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
0x091e6000 JavaThread "TimerQueue" daemon [_thread_blocked, id=4080, stack(0x0ac30000,0x0ac80000)]
0x091e5c00 JavaThread "J3D-InputDeviceScheduler-1" [_thread_blocked, id=3592, stack(0x09f60000,0x09fb0000)]
0x091e5400 JavaThread "J3D-SoundSchedulerUpdateThread-1" [_thread_blocked, id=3896, stack(0x09c10000,0x09c60000)]
0x06c99c00 JavaThread "J3D-RenderStructureUpdateThread-1" [_thread_blocked, id=3972, stack(0x09bc0000,0x09c10000)]
0x06c99400 JavaThread "J3D-BehaviorScheduler-1" [_thread_blocked, id=3924, stack(0x09b70000,0x09bc0000)]
0x06c99000 JavaThread "J3D-TransformStructureUpdateThread-1" [_thread_blocked, id=4076, stack(0x09b20000,0x09b70000)]
0x06c98800 JavaThread "J3D-RenderingEnvironmentStructureUpdateThread-1" [_thread_blocked, id=3176, stack(0x09ad0000,0x09b20000)]
0x06c98000 JavaThread "J3D-SoundStructureUpdateThread-1" [_thread_blocked, id=4040, stack(0x09a80000,0x09ad0000)]
0x06c97c00 JavaThread "J3D-GeometryStructureUpdateThread-1" [_thread_blocked, id=3000, stack(0x08c20000,0x08c70000)]
0x06c97400 JavaThread "J3D-BehaviorStructureUpdateThread-1" [_thread_blocked, id=4032, stack(0x08bd0000,0x08c20000)]
0x06c96800 JavaThread "AWT-EventQueue-1" [_thread_blocked, id=2972, stack(0x08af0000,0x08b40000)]
0x06c96400 JavaThread "AWT-EventQueue-0" [_thread_blocked, id=492, stack(0x08aa0000,0x08af0000)]
0x06c95c00 JavaThread "AWT-Shutdown" [_thread_blocked, id=484, stack(0x08a50000,0x08aa0000)]
=>0x06c95800 JavaThread "J3D-Renderer-1" [_thread_in_native, id=508, stack(0x07ff0000,0x08040000)]
0x06c95000 JavaThread "J3D-MasterControl-1" [_thread_blocked, id=3948, stack(0x07f00000,0x07f50000)]
0x06c94c00 JavaThread "J3D-NotificationThread" [_thread_blocked, id=3244, stack(0x071e0000,0x07230000)]
0x06c93800 JavaThread "J3D-TimerThread" [_thread_blocked, id=2996, stack(0x07140000,0x07190000)]
0x06c94000 JavaThread "J3D-RenderingAttributesStructureUpdateThread" [_thread_blocked, id=500, stack(0x06d60000,0x06db0000)]
0x06c94400 JavaThread "Thread-10" [_thread_in_native, id=268, stack(0x06e00000,0x06e50000)]
0x06c92c00 JavaThread "Keep-Alive-Timer" daemon [_thread_blocked, id=3976, stack(0x07e60000,0x07eb0000)]
0x06c92800 JavaThread "TimerQueue" daemon [_thread_blocked, id=176, stack(0x07780000,0x077d0000)]
0x06c92000 JavaThread "D3D Screen Updater" daemon [_thread_blocked, id=3936, stack(0x07330000,0x07380000)]
0x01e3c800 JavaThread "CacheCleanUpThread" daemon [_thread_blocked, id=1496, stack(0x070a0000,0x070f0000)]
0x01e3c000 JavaThread "CacheMemoryCleanUpThread" daemon [_thread_blocked, id=2880, stack(0x07050000,0x070a0000)]
0x01d0b400 JavaThread "DestroyJavaVM" [_thread_blocked, id=2356, stack(0x007b0000,0x00800000)]
0x01e3a000 JavaThread "Javaws Secure Thread" daemon [_thread_blocked, id=3828, stack(0x06db0000,0x06e00000)]
0x01e39800 JavaThread "AWT-Windows" daemon [_thread_in_native, id=2296, stack(0x01c00000,0x01d00000)]
0x01e38800 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=2456, stack(0x06a90000,0x06ae0000)]
0x01dfa400 JavaThread "traceMsgQueueThread" daemon [_thread_blocked, id=3156, stack(0x069f0000,0x06a40000)]
0x01dd1c00 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=2400, stack(0x05e40000,0x05e90000)]
0x01dce400 JavaThread "CompilerThread0" daemon [_thread_blocked, id=2192, stack(0x05df0000,0x05e40000)]
0x01dcd400 JavaThread "Attach Listener" daemon [_thread_blocked, id=2712, stack(0x05da0000,0x05df0000)]
0x01dca400 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=2204, stack(0x05d50000,0x05da0000)]
0x01d84c00 JavaThread "Finalizer" daemon [_thread_blocked, id=2220, stack(0x043e0000,0x04430000)]
0x01d83800 JavaThread "Reference Handler" daemon [_thread_blocked, id=2268, stack(0x042d0000,0x04320000)]
Other Threads:
0x01d82000 VMThread [stack: 0x01f10000,0x01f60000] [id=1484]
0x01dd7000 WatcherThread [stack: 0x05f30000,0x05f80000] [id=2284]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
def new generation total 5056K, used 3072K [0x13f00000, 0x14470000, 0x1e9a0000)
eden space 4544K, 58% used [0x13f00000, 0x14193718, 0x14370000)
from space 512K, 84% used [0x143f0000, 0x1445c970, 0x14470000)
to space 512K, 0% used [0x14370000, 0x14370000, 0x143f0000)
tenured generation total 10944K, used 5393K [0x1e9a0000, 0x1f450000, 0x33f00000)
the space 10944K, 49% used [0x1e9a0000, 0x1eee45f8, 0x1eee4600, 0x1f450000)
compacting perm gen total 12288K, used 9470K [0x33f00000, 0x34b00000, 0x37f00000)
the space 12288K, 77% used [0x33f00000, 0x3483fad8, 0x3483fc00, 0x34b00000)
ro space 10240K, 51% used [0x37f00000, 0x3842ae00, 0x3842ae00, 0x38900000)
rw space 12288K, 54% used [0x38900000, 0x38f972d8, 0x38f97400, 0x39500000)
Dynamic libraries:
0x00400000 - 0x00424000 C:\Program Files\Java\jre6\bin\javaw.exe
0x77d00000 - 0x77e27000 C:\Windows\system32\ntdll.dll
0x77e40000 - 0x77f1b000 C:\Windows\system32\kernel32.dll
0x76ef0000 - 0x76fb6000 C:\Windows\system32\ADVAPI32.dll
0x765d0000 - 0x76693000 C:\Windows\system32\RPCRT4.dll
0x76e50000 - 0x76eed000 C:\Windows\system32\USER32.dll
0x76580000 - 0x765cb000 C:\Windows\system32\GDI32.dll
0x76fc0000 - 0x76fde000 C:\Windows\system32\IMM32.DLL
0x76d20000 - 0x76de8000 C:\Windows\system32\MSCTF.dll
0x77140000 - 0x771ea000 C:\Windows\system32\msvcrt.dll
0x77e30000 - 0x77e39000 C:\Windows\system32\LPK.DLL
0x766f0000 - 0x7676d000 C:\Windows\system32\USP10.dll
0x7c340000 - 0x7c396000 C:\Program Files\Java\jre6\bin\msvcr71.dll
0x6d800000 - 0x6da97000 C:\Program Files\Java\jre6\bin\client\jvm.dll
0x74170000 - 0x741a2000 C:\Windows\system32\WINMM.dll
0x76800000 - 0x76944000 C:\Windows\system32\ole32.dll
0x76770000 - 0x767fd000 C:\Windows\system32\OLEAUT32.dll
0x74130000 - 0x74169000 C:\Windows\system32\OLEACC.dll
0x763b0000 - 0x763dc000 C:\Windows\system32\apphelp.dll
0x6d7b0000 - 0x6d7bc000 C:\Program Files\Java\jre6\bin\verify.dll
0x6d330000 - 0x6d34f000 C:\Program Files\Java\jre6\bin\java.dll
0x6d000000 - 0x6d14a000 C:\Program Files\Java\jre6\bin\awt.dll
0x71c80000 - 0x71cc2000 C:\Windows\system32\WINSPOOL.DRV
0x75300000 - 0x7549e000 C:\Windows\WinSxS\x86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.6001.18000_none_5cdbaa5a083979cc\COMCTL32.dll
0x76cc0000 - 0x76d18000 C:\Windows\system32\SHLWAPI.dll
0x6d290000 - 0x6d298000 C:\Program Files\Java\jre6\bin\hpi.dll
0x764e0000 - 0x764e7000 C:\Windows\system32\PSAPI.DLL
0x74e20000 - 0x74e5f000 C:\Windows\system32\uxtheme.dll
0x6d7f0000 - 0x6d7ff000 C:\Program Files\Java\jre6\bin\zip.dll
0x70050000 - 0x7020a000 C:\Windows\system32\d3d9.dll
0x75cc0000 - 0x75cc8000 C:\Windows\system32\VERSION.dll
0x71900000 - 0x71906000 C:\Windows\system32\d3d8thk.dll
0x73f90000 - 0x73f9c000 C:\Windows\system32\dwmapi.dll
0x6e560000 - 0x6e568000 C:\Windows\system32\atiu9pag.dll
0x6c970000 - 0x6ccfe000 C:\Windows\system32\atiumdag.dll
0x6c670000 - 0x6c962000 C:\Windows\system32\atiumdva.dll
0x6d1d0000 - 0x6d1e3000 C:\Program Files\Java\jre6\bin\deploy.dll
0x75ec0000 - 0x75fb1000 C:\Windows\system32\CRYPT32.dll
0x76020000 - 0x76032000 C:\Windows\system32\MSASN1.dll
0x76430000 - 0x7644e000 C:\Windows\system32\USERENV.dll
0x76410000 - 0x76424000 C:\Windows\system32\Secur32.dll
0x771f0000 - 0x77cff000 C:\Windows\system32\SHELL32.dll
0x76ae0000 - 0x76baf000 C:\Windows\system32\WININET.dll
0x76e40000 - 0x76e43000 C:\Windows\system32\Normaliz.dll
0x76df0000 - 0x76e35000 C:\Windows\system32\iertutil.dll
0x76fe0000 - 0x77108000 C:\Windows\system32\urlmon.dll
0x6d610000 - 0x6d623000 C:\Program Files\Java\jre6\bin\net.dll
0x77110000 - 0x7713d000 C:\Windows\system32\WS2_32.dll
0x77f20000 - 0x77f26000 C:\Windows\system32\NSI.dll
0x75bb0000 - 0x75beb000 C:\Windows\system32\mswsock.dll
0x75cb0000 - 0x75cb5000 C:\Windows\System32\wship6.dll
0x6d630000 - 0x6d639000 C:\Program Files\Java\jre6\bin\nio.dll
0x6d6b0000 - 0x6d6f4000 C:\Program Files\Java\jre6\bin\regutils.dll
0x6d230000 - 0x6d284000 C:\Program Files\Java\jre6\bin\fontmanager.dll
0x75890000 - 0x75895000 C:\Windows\System32\wshtcpip.dll
0x71460000 - 0x714aa000 C:\Windows\system32\RASAPI32.dll
0x743a0000 - 0x743b4000 C:\Windows\system32\rasman.dll
0x76270000 - 0x762e5000 C:\Windows\system32\NETAPI32.dll
0x711c0000 - 0x711f1000 C:\Windows\system32\TAPI32.dll
0x74f90000 - 0x74f9c000 C:\Windows\system32\rtutils.dll
0x71870000 - 0x71876000 C:\Windows\system32\sensapi.dll
0x75ce0000 - 0x75ce7000 C:\Windows\system32\credssp.dll
0x759e0000 - 0x75a24000 C:\Windows\system32\schannel.dll
0x758d0000 - 0x758f1000 C:\Windows\system32\NTMARTA.DLL
0x766a0000 - 0x766ea000 C:\Windows\system32\WLDAP32.dll
0x76040000 - 0x76051000 C:\Windows\system32\SAMLIB.dll
0x757c0000 - 0x757cf000 C:\Windows\system32\NLAapi.dll
0x75e20000 - 0x75e39000 C:\Windows\system32\IPHLPAPI.DLL
0x75de0000 - 0x75e15000 C:\Windows\system32\dhcpcsvc.DLL
0x76060000 - 0x7608c000 C:\Windows\system32\DNSAPI.dll
0x75dd0000 - 0x75dd7000 C:\Windows\system32\WINNSI.DLL
0x75da0000 - 0x75dc1000 C:\Windows\system32\dhcpcsvc6.DLL
0x735a0000 - 0x735af000 C:\Windows\system32\napinsp.dll
0x73580000 - 0x73592000 C:\Windows\system32\pnrpnsp.dll
0x73540000 - 0x73548000 C:\Windows\System32\winrnr.dll
0x73520000 - 0x73526000 C:\Windows\system32\rasadhlp.dll
0x759a0000 - 0x759db000 C:\Windows\system32\rsaenh.dll
0x10000000 - 0x1000e000 C:\Users\Алексей\AppData\Local\Temp\extension8505230814731185991.dll
0x6bf20000 - 0x6bfeb000 C:\Windows\system32\OPENGL32.dll
0x75050000 - 0x75073000 C:\Windows\system32\GLU32.dll
0x6df90000 - 0x6e075000 C:\Windows\system32\DDRAW.dll
0x74390000 - 0x74396000 C:\Windows\system32\DCIMAN32.dll
0x76950000 - 0x76ada000 C:\Windows\system32\SETUPAPI.dll
0x75090000 - 0x75097000 C:\Windows\system32\atiglpxx.dll
0x69030000 - 0x69df7000 C:\Windows\system32\atioglxx.dll
0x75040000 - 0x75047000 C:\Windows\system32\atigktxx.dll
0x07eb0000 - 0x07eea000 C:\Windows\system32\atiadlxx.dll
0x75700000 - 0x7572d000 C:\Windows\system32\WINTRUST.dll
0x77f30000 - 0x77f59000 C:\Windows\system32\imagehlp.dll
0x6d360000 - 0x6d366000 C:\Program Files\Java\jre6\bin\jawt.dll
0x08660000 - 0x08733000 C:\Users\Алексей\AppData\Local\Temp\extension105815763305391408.dll
0x6d1a0000 - 0x6d1c3000 C:\Program Files\Java\jre6\bin\dcpr.dll
VM Arguments:
jvm_args: -Xbootclasspath/a:C:\Program Files\Java\jre6\lib\javaws.jar;C:\Program Files\Java\jre6\lib\deploy.jar;C:\Program Files\Java\jre6\lib\plugin.jar -Djava.security.policy=file:C:\Program Files\Java\jre6\lib\security\javaws.policy -DtrustProxy=true -Xverify:remote -Djnlpx.home=C:\Program Files\Java\jre6\bin -Dsun.awt.warmup=true -Djnlpx.origFilenameArg=C:\Users\Алексей\AppData\LocalLow\Sun\Java\Deployment\cache\6.0\17\6db71e91-2effb448 -Djnlpx.remove=false -Xmx512m -Djnlpx.heapsize=NULL,512m -Djnlpx.splashport=49255 -Djnlpx.jvm=C:\Program Files\Java\jre6\bin\javaw.exe
java_command: com.sun.javaws.Main -offline C:\Users\Алексей\AppData\LocalLow\Sun\Java\Deployment\cache\6.0\17\6db71e91-2effb448
Launcher Type: SUN_STANDARD
Environment Variables:
CLASSPATH=.;C:\Program Files\QuickTime\QTSystem\QTJava.zip
PATH=C:\Program Files\Java\jre6\bin;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Program Files\QuickTime\QTSystem\;C:\Program Files\Common Files\DivX Shared\;D:\php-5.3.1;C:\Program Files\MySQL\MySQL Server 5.1\bin;C:\Program Files\Sun\JavaDB\bin;"C:\Program Files\Java\jre6\bin"
USERNAME=Алексей
OS=Windows_NT
PROCESSOR_IDENTIFIER=x86 Family 6 Model 15 Stepping 11, GenuineIntel
--------------- S Y S T E M ---------------
OS: Windows Vista Build 6001 Service Pack 1
CPU:total 2 (2 cores per cpu, 1 threads per core) family 6 model 15 stepping 11, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ssse3
Memory: 4k page, physical 3142344k(1942128k free), swap 6539720k(5477936k free)
vm_info: Java HotSpot(TM) Client VM (16.2-b04) for windows-x86 JRE (1.6.0_19-b04), built on Mar 9 2010 00:48:41 by "java_re" with MS VC++ 7.1 (VS2003)
time: Thu Apr 15 08:54:09 2010
elapsed time: 16 seconds
Thank you. I reported it to Java 3D team. [:)]
