Years of Projects hang on MacBookProM1Max after Sonoma 14.1.1 update?
This topic has been viewed 8756 times and has 14 replies
rolffj
Country: Canada
Post by rolffj »
After years of successful use of paid version via Mac AppStore, program (regularly updated to 7.2.1) and all projects (now showing "Recover" added to names) now hang with spinning beach ball on MacBookProM1Max after upgrading to Sonoma 14.1.1 (not beta). Attempts to reopen via App Store prior purchase "Open" link produce same hanging results.
For troubleshooting, downloaded free Java 8 version 7.2 that does open (with limited libraries of course), yet crashes if try to open any recent projects. Can begin a new project only on free version.
How might I regain access to earlier projects and extensive libraries that I previously imported, please? Thank you for the assistance.
Re: Years of Projects hang on MacBookProM1Max after Sonoma 14.1.1 update?
How big are your SH3D file? Your projects might have become very large in which case you should try to increase the max memory used the program.
rolffj
Country: Canada
Post by rolffj »
Was able to expand memory to 6GB per instructions. However, program still hangs until force quit.
Recent project file size trying to open only 1.2MB (though 600kb version also won't open), while earlier ones were 13.8MB and as large as 36MB (with 3D view routinely separated onto a second or third monitor).
Additional sugestions, please? Thank you.
Your files are quite small, so the problem must come from something else.
Did you import some large 3D models?
rolffj
Country: Canada
Post by rolffj »
The Applications/SweetHome folder where all the models and multiple imported libraries of many doors, stairs, roofs, etc. appear to be is 334MB in size. The separate folder with all my projects is 490MB. The terrabyte hard drive has 189GB available besides extending onto multiple external drives as needed. Insights?
rolffj
Country: Canada
Post by rolffj »
I like the program and don't object to purchasing it again if I'm guided via links on how to delete everything except the projects and libraries, if possible. I feel like having the 7.2 Universal and iOS and 7.2.1 Mac App Store versions simultaneously on my computer from troubleshooting attempts may be making things worse? Is that likely? Thanks again.
Having both versions installed on the same computer is not a problem, except of course if you try to save a same file opened in both applications at the same time.
As explained here, imported 3D models and textures are not saved at the same place for both applications, and this is the only thing that may trouble users who are not aware of this.
Could you check the contents of Library/Containers/com.eteks.sweethome3d.SweetHome3D/Data/Library/Application Support/eTeks/Sweet Home 3D folder?
In the Finder, select Go > Go To... menu item, then enter ~/Library/Containers/com.eteks.sweethome3d.SweetHome3D/Data/Library/Application Support/eTeks/Sweet Home 3D (with the tilde) and press <enter>. If that folder contains a folder named "recovery", moving it elsewhere will let you restart the Mac App Store verison of Sweet Home 3D and open your SH3D files.
rolffj
Country: Canada
Post by rolffj »
That seemed to work to get the program open with full libraries, thank you.
Exception is only a few older project files open without force quit, yet I can recreate the few still needed later. The only one in Recovery folder still hangs but OK for now.
Also the "com.eteks.sweethome3d" portion was not in the path, instead going directly from /Containers to SweetHome3D/
Do I empty the moved Recovery folder and place it back where it was in case ever needed again, or just leave it where I moved it earlier in that path as I have done that worked?
Thank you very much for the patient and thorough assistance. You've created a wonderful program that is appreciated! Merci
You're welcome [:)]
Both paths work, Sweet Home 3D being a shortcut of com.eteks.sweethome3d.SweetHome3D.
Please, [url=mailto:[email protected]]send me[/url] the file found in Recovery folder if you don't mind. It shouldn't hang program launch, and it will help me to understand why.
You can discard the Recovery folder if you want. It will be created again if needed.
rolffj
Country: Canada
Post by rolffj »
Attached to an email as requested. Thanks again.
