The rendering doesn't start.
This topic has been viewed 3803 times and has 1 replies
architetto20
Hi everyone, I'm using Sweet Home 3D. When I launch the "Create 3D Photo" command, the window opens and then freezes on the first rendering frames. I tried closing the program and reopening it, but when I repeat the command, the rendering window freezes and an "X" appears. Help! [:(] [:(]
Re: The rendering doesn't start.
This may happen when the program don't have enough memory at disposal. Try to increase the maximum memory Sweet Home 3D may use by following these instructions.
If it doesn't fix your issue, try to remove some furniture from your design removing the big ones first (display the Model size column to help you find them).
