Installation doesn't work. Software doesn't start.
This topic has been viewed 8924 times and has 6 replies
abhishka
Country: India
Post by abhishka »
I have purchased this product and when installed on my Mac only the start screen comes up but no other screen. Its the home loader screen which says the name of the software.
OS - OS X Yosemite
Processor - 2.5 Ghz Intel Core i7
Memory 16GB 1600 Mhz DDR3
Startup Disk - Machintosh HD
Graphics - AMD Radeon R9 M370x 2048 MB
Re: Installation doesn't work. Software doesn't start.
Really strange... This kind of problem may happen on other systems, but not on macOS [:(]
Would you be able to run Sweet Home 3D from a Terminal window to report here the messages it will say? Simply drag and drop Sweet Home 3D application in a Terminal window, type back space, copy-paste [font=courier new]/Contents/MacOS/SweetHome3D[/font] and press enter.
You could try also the free version but it will require that you install Java 6 too.
martyt3
Country: United Kingdom
Post by martyt3 »
It wont start for me either. Im on win 7
Martyt3, could you try version 5.3 beta 7?
jlecour
Post by jlecour »
I have a similar issue. The program starts, I get the spashscreen, but it's frozen.
~ → /Users/jlecour/Desktop/Sweet\ Home\ 3D.app/Contents/MacOS/SweetHome3D
[JavaAppLauncher] Requested [1.5*], launching in [1.8] instead.
Exception in thread "J3D-Renderer-1" java.lang.UnsatisfiedLinkError: no jogl in java.library.path
	at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1867)
	at java.lang.Runtime.loadLibrary0(Runtime.java:870)
	at java.lang.System.loadLibrary(System.java:1122)
	at com.sun.opengl.impl.NativeLibLoader.loadLibraryInternal(NativeLibLoader.java:189)
	at com.sun.opengl.impl.NativeLibLoader.access$000(NativeLibLoader.java:49)
	at com.sun.opengl.impl.NativeLibLoader$DefaultAction.loadLibrary(NativeLibLoader.java:80)
	at com.sun.opengl.impl.NativeLibLoader.loadLibrary(NativeLibLoader.java:103)
	at com.sun.opengl.impl.NativeLibLoader.access$200(NativeLibLoader.java:49)
	at com.sun.opengl.impl.NativeLibLoader$1.run(NativeLibLoader.java:111)
	at com.sun.opengl.impl.NativeLibLoader.loadCore(NativeLibLoader.java:109)
	at com.sun.opengl.impl.macosx.MacOSXGLDrawableFactory.<clinit>(MacOSXGLDrawableFactory.java:53)
	at java.lang.Class.forName0(Native Method)
	at java.lang.Class.forName(Class.java:264)
	at javax.media.opengl.GLDrawableFactory.getFactory(GLDrawableFactory.java:108)
	at javax.media.j3d.JoglPipeline$QueryCanvas.<init>(JoglPipeline.java:9029)
	at javax.media.j3d.JoglPipeline.getBestConfiguration(JoglPipeline.java:8793)
	at javax.media.j3d.Renderer.doWork(Renderer.java:514)
	at javax.media.j3d.J3dThread.run(J3dThread.java:275)
Jeremy, the first message of this thread talks about the Mac App Store version. Are you sure you're talking about that version or the free version? If it's the free version, would you have some jar files in the folder ~/Library/Java/Extensions if it exists? If it's the case, remove them, it should work better.
jlecour
Post by jlecour »
Right, I'm using the free version. I didn't notice that aspect. Sorry.
Also, the "~/Library/Java/Extensions" doesn't exist (not even "~/Library/Java").
