changing line width in PDF export
This topic has been viewed 3450 times and has 1 replies
olh
Post by olh »
in a simple room with dimensioning, the lines for the room itself and the lines for the dimensions of each wall have apparently the same thickness in the 2D PDF export.
Is there a way to draw the lines for the room thicker, and the lines for dimensions thinner? I looked for an option to change this behavior, but did not spot it in my version 7.5.
Thank you.
MarioSambol
Country: Croatia
Re: changing line width in PDF export
Post by MarioSambol »
I don't think you can change the thickness. You can only change the font size at the moment.
