3D View "Display In Separate Window" Causes Hangs
This topic has been viewed 9907 times and has 13 replies
A.D.STUDIO
- Country: Australia
Thanks for the 7.4 update. There's a note about separating the 3D view on a separate monitor would cause freezes but now fixed. However, I separate this window on a single monitor and I can guarantee a hang after toggling around six times. This is with ONE model in the plan.
A.D.STUDIO
Re: 3D View "Display In Separate Window" Causes Hangs
I think there's a severe memory leak going on, my RAM is maxed out after doing this...
Thanks A.D.STUDIO!
I've encountered the same problem even I'm under linux (debian) on both computers (at work and at home).
Symptoms: SH3D don't start even with an empty file.
Result in konsole:
Solution for linux users found on the net:
What fixed it was this command as root (su -) (sudo didn't do it):
Then reboot.
Solutions found here and here .
I hope it will help someone.
Result in konsole:
library initialization failed - unable to allocate file descriptor table - out of memorySolution for linux users found on the net:
echo >/etc/security/limits.d/systemd.conf "* hard nofile 1048576"Then reboot.
I was able to reproduce this issue by using the shortcut for Display in separate window / Display in main window menu items (Ctrl + Alt + Y) many times quickly. Andy, is it what you tried on your side?
I found it wasn't a memory leak issue, but rather a problem of synchronization between separate / not separate state of the 3D view. Anyway, I fixed it and the correction will be available in the next version.
A.D.STUDIO
@Puybaret, yes that is exactly what has been happening to me. Thank you for looking into it and I look forward to the update.
Don’t expect an update too soon and meanwhile, avoid attaching / detaching the 3D view too quickly.
A.D.STUDIO
Would you consider releasing a beta or something for me to test? I'm not actually toggling that fast and have a presentation in a week.
Is it so difficult to refrain yourself from toggling detached 3D view?!?
Or maybe your project is huge or it’s another issue.
By the way, I noticed that the program didn't hang. If you click in the main window, it will activate it and you can continue to use it.
A.D.STUDIO
OK well it hangs for me. Not sure why you'd offer detached 3D view if you don't think people should use it. I'm on a single screen, and because it can be done with a key command, I can go full screen 3D with a button press, and back again, which is actually quite convenient.
