Is this normal?
This topic has been viewed 7418 times and has 6 replies
gernith
Is this normal?
Post by gernith »
Every now and then I get stuck in this window, and I can't find a way out. I can't see any of the walls I've created, or the gridlines to draw them on? Is this a known problem?
Re: Is this normal?
It looks like this fixed bug, but probably a little different.
Please send [url=mailto:[email protected]]me[/url] your Sweet Home 3D file or/and try this:
1. Launch Console program found in /Applications/Utilities folder and click on Clear display.
2. Launch Sweet Home 3D and open your file.
3. Console program should display some new text that will help me a lot to guess your issue. Please select that text and copy paste it in a comment here.
gernith
Re: Is this normal?
Post by gernith »
Thanks for the help. If I remember correctly, the file is only a few walls as I was just learning the program. Here's the log, I'll send the file from my yahoo email account.
11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] Exception in thread "AWT-EventQueue-0" javax.media.j3d.BadTransformException: TransformGroup: non-affine transform
11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] at javax.media.j3d.TransformGroup.setTransform(TransformGroup.java:137)
11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] at com.eteks.sweethome3d.swing.HomeComponent3D.updateViewPlatformTransform(Unknown Source)
11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] at com.eteks.sweethome3d.swing.HomeComponent3D.createUniverse(Unknown Source)
11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] at com.eteks.sweethome3d.swing.HomeComponent3D.access$100(Unknown Source)
11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] at com.eteks.sweethome3d.swing.HomeComponent3D$1.ancestorAdded(Unknown Source)
11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] at javax.swing.AncestorNotifier.fireAncestorAdded(AncestorNotifier.java:68)
11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] at javax.swing.AncestorNotifier.componentShown(AncestorNotifier.java:175)
11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] at java.awt.AWTEventMulticaster.componentShown(AWTEventMulticaster.java:122)
11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] at java.awt.AWTEventMulticaster.componentShown(AWTEventMulticaster.java:121)
11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] at java.awt.Component.processComponentEvent(Component.java:5434)
11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] at java.awt.Component.processEvent(Component.java:5382)
11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] at java.awt.Container.processEvent(Container.java:2010)
11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] at java.awt.Window.processEvent(Window.java:1184)
11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] at java.awt.Component.dispatchEventImpl(Component.java:4068)
11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] at java.awt.Container.dispatchEventImpl(Container.java:2068)
11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] at java.awt.Window.dispatchEventImpl(Window.java:1801)
11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] at java.awt.Component.dispatchEvent(Component.java:3903)
11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] at java.awt.EventQueue.dispatchEvent(EventQueue.java:463)
11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] at java.awt.EventDispatchThread.pumpOneEventForHierarchy(EventDispatchThread.java:269)
11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:190)
11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:184)
11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:176)
11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] at java.awt.EventDispatchThread.run(EventDispatchThread.java:110)
11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] Tue Nov 10 12:35:52 ssds-macbook-pro-2.local JavaApplicationStub[142] <Error>: CGContextClosePath: no current point.
11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] Tue Nov 10 12:35:52 ssds-macbook-pro-2.local JavaApplicationStub[142] <Error>: CGPointApplyInverseAffineTransform: singular matrix.
gernith
Re: Is this normal?
Post by gernith »
Any thoughts? More info I can provide?
gernith
Re: Is this normal?
Post by gernith »
Downloading the new 2.2, I still get the same issues with the file I sent you. I think I may have narrored it down to the "double electric outlet" http://www.sweethome3d.eu/models/contri ... utlet2.zip
adding it to the model seems to cause the error.
Re: Is this normal?
I don't know how, but you succeeded to set a null value for the depth of the electric outlet placed in your home. If you know how to reproduce this problem, please describe it here.
gernith
Re: Is this normal?
Post by gernith »
From the furniture menu I chose import furniture, find models, which caused http://www.sweethome3d.eu/importModels.jsp to load in my safari web browser. I chose the "Double electric outlet" which downloaded and expanded "electricOutlet2.obj". From the furniture menu I chose import furniture, choose model, and located the "electricOutlet2.obj" file. The continue, continue, continue, finish, without changing any dimensions. Here's what it lists the dimensions as:
Then I clicked and dragged "electricOutlet2" on to a wall in the floor plan. This is when the problem occurs.
