I'm newbie. is this normal?
This topic has been viewed 10612 times and has 6 replies
in the 3D view of my house some walls are transparent, is this normal? and also I can not create pictures, all somebody can tell me why and if you have any solution to this?
Re: I'm newbie. is this normal?
First time that somebody reports this strange issue...
Could you check if there's any update of the driver for your graphics card?
What is your system?
I had a similar thing happening (4.0, Win8): a wall becoming semi-transparent. The disturbance, _I think_, came from:
- a window/door model (self made, .dae), AND / OR
- walls overlapping between levels (first level going well into the second, including walls and presumably rooms with ceilings too).
Unfortunately I didn't save the file.
the graphics card driver is the most up to date ....
I have W7 32-bit, 1GB RAM and also I have the version 4.0 but with previous versions the same thing happens
Could you [url=mailto:[email protected]]send me[/url] your file? Maybe you did something unexpected?
By the way, the photo creation should at least work correctly at the two best quality levels.
I just sent the file ... I hope that if have slucion
Sorry but I couldn't reproduce your issue on my computer. [:(]
In a future version (not the one released tonight), a major update of the Java3D library should appear. You'll have to check if it works better at that moment.
