3D rotation of an Object
This topic has been viewed 6822 times and has 5 replies
MarcoTorinoItaly
Post by MarcoTorinoItaly »
I am drawing an attic with a pitched roof.
I have designed the roof in SweetHome and saved it as object.
I then import it as object (furniture import) in the main draw of the attic and in included in the library in the category of miscellaneous objects.
Issue is that I need to rotate now the roof in 3D in order to align it to the below sloping walls .
I need to use all 3 axis or rotation directly on the CAD. Below the image:
https://drive.google.com/file/d/1gOTT0D ... sp=sharing
Is it possible ?
thanks !
Re: 3D rotation of an Object
You can’t rotate an object around 3 axes in Sweet Home 3D, except in the 2nd step of the import wizard.
dorin
Post by dorin »
Is it possible ?
Yes.
Select the object after insert in plan;
Right click->modify furniture->set the rotation angle on 3 axis.
Will don't work until You selected again after insertion.
MarcoTorinoItaly
Yes,thanks, i tried but it is pretty dufficult to pick the right angle, rotation 3d, and furthermore once i change the angle it goes in totaly wrong position. Maybe i have to select it again as you suggest...
Would the below help to draw the roof of my attic ?
http://www.sweethome3d.com/support/foru ... 0_offset,0
dorin
Post by dorin »
For simple roofs could help but for some little more complex don't.
Especially if you want to insert some windows or an unregulated shape of roof.
Is not quite a simple task but with perseverance You will succeed.
Sometime You need to elevate more than necessary to be able to rotate, then set the correct elevation and orientation.
UbuntuBirdy
Country: Switzerland
Post by UbuntuBirdy »
Do it like Puybaret wrote: reimport your roof and turn it to the position you need in the 2nd step of the import wizard.
Pascal
